  2. Brian Tucker joined the community
  4. Rose Mc joined the community
  5. I know... so nothing. But, Thanks.
  6. I use iCarSoft scanner so not sure about the Topdon but most scan tools are of the same standard and will read and delete fault codes. Beyond that, scanners such as the iCarSoft can also code injectors, reset base values and quite a bit more
  7. The only thing I can think of is when you lock/unlock and hold the button down for a period of time then the windows will lower or raise? Otherwise, not sure what could be causing it to drop the windows
  8. Here is some more information on the fault and a video showing how to fix it (Google AI search of fault code P0002) P0002 is an OBD-II diagnostic trouble code for a fuel volume regulator control circuit range/performance issue, indicating the engine control unit (ECU) has detected a problem with the fuel volume regulator. This can be caused by a faulty fuel pump, regulator, or a problem with wiring, connectors, or a clogged fuel filter. Symptoms often include a illuminated check engine light, poor engine performance, and the vehicle entering "limp mode".
  9. Last week
  10. In diagnostic, "Consult" for Nissan? I tryed... and nothing, Dealer Nissan and nothing. Car is normally go, but maybe I listening turbo pressure up\down. Blick red error of motor and car is normally go, but pressure is normal at now. I Stop the car and again start the motor, and error is resset some kilometrs. Insane car... realy
  11. feldo joined the community
  12. Is there a known issue with 2010 Muranos that causes the front windows to lower without input?
  13. sped98 joined the community
  14. Ronnie joined the community
  15. Shortcircuit123 joined the community
  16. I am considering having a Topdon Carpal as my OBD diagnostic tool. Has anyone on this forum had any experience of this model?
  17. Gavcole joined the community
  18. KRANTHI joined the community
  19. Can you turn of off the electric mirror fold , so is it possible to move them in/out manually ? So I can get the car in / out of the garage
  20. I don't have any faith whatsover with the current clowns in power so I wouldn't do anything hastily such as changing your car as it is always likely to change in the near future
  21. Tendai 7 joined the community
  22. As the E POWER vehicles are hybrid but NOT plug-in hybrid will they have to pay the new budget charge per mile levy. As the electricity used is solely produced by the petrol engine then all excise duty has been paid. If this new charge is applied to these vehicles then surely you are paying twice. Nissn E POWER vehicles should be exempt. Hopfully other E POWER owners have the same views, please feed back
  23. Sounds like the new settings need to be programmed in - e.g. new DPF,etc base readings
  24. Trevor started following NV200- error P0002
  25. Hello I would like some help with my car NV200, 1.5dci, 81kW, 2014. Consult diagnostic have error: P0002 Flow controller adaptive 2.DEF P0002 Flow controller adaptive 4.DEF Autorized servis Nissan, They are not know. Refrebushied: fuel pressure pump, injectors, fuel filtr, regeneration dpf, rail pressure sensor, turbo... Thanks for information.
  26. xJanx started following NV200- error P0002
  27. I have the joy of owning a 2014 Pathfinder with the CVT transmission. Was acting terrible, bad lurching, when shifting into D or reverse it would pause for about 5 seconds then grab. It also barelyl got to speed, so was a safety issue. After some research and error code P0776 Pressure Control Solonoid B, I replaced the valve body, with one off Amazon that in the description says "There is no software CD, itis installed directly" https://www.amazon.com/dp/B0FMFB9FVM?ref=ppx_yo2ov_dt_b_fed_asin_title Well after installing that with new CVT fluid, it has a very violent shake (judder maybe?) when starting to drive maybe 1 mph. New codes: P0746 Pressure Control solonoid A ( seems odd for a new valve body) P0847 Trans fluid pressure circuit b low (i would think this is on the valve body also) P084C Trans fluid pressure sensor H circuit Low, and using CVTx50 on a tablet, see the dreaded judder code: P17F0. So, I would like to know, is it mandatory to get a CD with a new valve body? Then how come several I have seen on Amazon and Ebay say it doesn't need one, or no mention at all? What about those decent reviews. It sounds like it is plug n play based on what I have seen so far. Yet on the other, need a CD, take to dealer $$$$. Can anyone please help me sort all this out?
  28. Earlier
  29. Which ‘control switch’?
  30. The dealership should walk you through the car if you have bought through them. Best to take someone along with you to aid your memory, I know because I get told things and promptly forget them :-)
  31. Its such a scam and see it all the time - easy money for the garages. It is possible to fit replacement rubbers if all they are is perished. As long as they are not perforated and leaking grease or if there is any play in the joints then it is perfectly serviceable. Advise on the MOT sheet but not necessary to replace otherwise. Recently fitted a replacement lower arm on wife's Juke and then replaced it a year later as the first (cheaper one) knocked the joint out in no time - more expensive one, quite a bit heavier duty for the N/S location and almost twice the weight. An easy job to carry out yourself and definitely not £1200 worth of repairs. Kept the old rubbers to use if necessary in the future. :-)
  32. Hi .... welcome to the Club Good to have you onboard
  33. Check maintenance and service history and there would be signs of any abuse with wear and tear in the interior - I always believe it is has been allowed to be grubby inside then they don't tend to look after the vehicle maintenance
  34. Code p0111 relates to intake air temp sensor Put VW P0111 into google search and comes up with a few videos of location and replacement
  35. Hello. 2021 Nissan Murono SV AWD V6 Using a Topdon Airlite 900 Getting a DTC P0111 which shows air intake temp sensor bank one. Looking online it appears that may be misleading as everything i see in reference to P0111 has to do with VVT on bank 1. See image. Trying to find location of VVT solenoid to clean and test, check wiring, or replace. Anyone have diagrams or exploded view???
  36. Hello. Ran across the forum while search for answers on a 2021 murano issue. I'll post a topic on that soon. Hope to find help here and provide a little if I can
  37. Hi , mithering old pensioner hither. Does any fellow Qashqai driver know of any training classes or just help from the dealers to understand how to drive it safely. Bearing in mind we struggle with our mobile phones. Help please
  38. Hi everybody just in the process of buying 2022 Qashqai, any tips to ask at the sale
  39. Been told by Nissan dealer after 60, 000 mile service that the front ball joint rubbers have split. No mention of issue with the bearings. Not too bad I thought. They say the part comes in one bit and have quoted me £1200 to replace them. Is this reasonable. Customer at the next desk to me appeared to have the same issue
