  2. Maybe consider an aftermarket double-din style replacement audio head unit far more function and cheaper than a replacement probably
  3. Manual or automatic transmission? Manual, would be halfway up the gearbox Automatic maybe prefilled or a dipstick somewhere
  4. You could trawl the internet as there are plenty of listings on there for downloadable manuals. Otherwise not sure, sorry Good to have you onboard!
  5. Hi....welcome to the Club Good to have you onboard!
  6. Hi....welcome to the Club Good to have you onboard!
  7. Problem with the radio and sat nav sd card keep popping out can’t stay in and screen say red contacts Nissan dealer radio play 10 minutes it turn off ???
  8. Yesterday
  9. 😀my front spring snapped and I have just had both front springs replaced. My Navara now bounces when going over speed humps. It never did that before. Are there different tensions of springs ?
  10. Hello, I have a 2011 Navara 4 door. I need two left passenger doors due rust, Nissan said I would need 2008–2014 but on eBay they’re listed to fit 2005-2015. I’ve found a 57 plate at the scrapyard. Can anyone shed any light to it they’ll fit?
  11. Last week
  12. Hi folks Could anyone please tell me where we fill up the transmission fluid. Plus where to buy a van manual, has anyone converted this type of Nissan into a motor home? Any issues with rust around the roof line? And whats a good fix? Cheers Oliver
  13. My cruise control comes on but I can't set it can anyone help me please
  14. Earlier
  15. Hi Everyone, just bought a 2013 Nissan Serena Hybrid and I was wondering does anyone know where I can get a free user manual download
  16. I purchased a defeat module off Ali Express, this allows me to have the stop /start either on, as per Nissan design or totally off . which is my preference having twice been stranded turning right on the very busy A46, and narrowly avoided being totalled on both occasions.
  17. Version 7, which I believe is the latest version, SD cards available on E Bay - but make sure you get the correct one for your car
  18. Tensioner assembly is 119553VA0C, found it at Arnold Clark, not sure if you can buy the tensioner pulley separately but you could call them https://www.arnoldclarkautoparts.com/products/genuine-nissan-tensioner-assy-119553va0c
  19. does this allow the key to start the car or what i have a prob with immobiliser coming in now and again can i over ride that or what thanks for any help with this
  20. The part number is 23150-bc40a Oops sorry that's the pulley, will try and find tensioner
  21. Saying hello as a new member, been a member previously, now an X Trail owner after three Qashqaiss
  22. Hi all Just popped in to say hello from Kingston upon Hull. About to purchase my first Nissan. A 1.0 DIG-T 117 N-Sport 2019. After having issues with Ford. Hopefully, i have chosen wisely.
  23. Hi all Hope you can help. Just got rid of my Fiesta because of the wet belt issues. I'm about to purchase the 1.0 DIG-T 117 N-Sport 2019. Please tell me the car does not utilise the wet belt system. I'm not very knowledgeable about cars, so your assistance is most welcome. Anyone, that has a 1.0 DIG-T 117 N-Sport. Have i made a good decision purchasing this model? thanks again
  24. Looks like it needs programming through specialist equipment either dealership or good independent garage
  25. Hi all, I've recently purchased a pixo but I'm in need of a windscreen washer cap replacement as mine doesn't have one. I'm struggling to find one as it's not round more a oval shape. Anyone on here got any ideas how I can sort this please. Cheers in advance Glyn.
  26. are you holding the unit completely vertical when you are attempting to retract it?
  27. answered in the other post you made
  28. Trevor
    New battery
    It depends on the age of the vehicle but it should be fine to just fit and then reset the audio system security code if necessary Disconnect the negative first and reconnect the negative last Ensure you have the keys to hand then lock the doors and unlock (may take a few presses of the lock button initially)
