Engine Warning Light
daniellove1981
hi :rolleyes:
new to the club.
My name is Dan and i'm having issues with the old girl... 2003 Micra with the engine warning light on.
Cold mornings..... start the car and drive off! then the car cuts out :( turn off the ignition, wait for the click (after about 5 seconds) then switch back on... Everything works fine apart from Engine Light still on.
Scary thing is, this has happened when the engine is warm and travelling on the motorway! Same procedure as above whilst cruising at 70mph...
Tried a new camshaft sensor (cheapest option) from a breakers yard (original Nissan part) and this rectified the issue for about 6 months... guess what.... problem reappeared about a month ago. Tried an new sensor from Euro Car parts and this just made the problem worse...
Anybody got any thoughts???
Many thanks
Dan.
