November 26Nov 26 HelloI would like some help with my car NV200, 1.5dci, 81kW, 2014.Consult diagnostic have error: P0002 Flow controller adaptive 2.DEFP0002 Flow controller adaptive 4.DEFAutorized servis Nissan, They are not know.Refrebushied: fuel pressure pump, injectors, fuel filtr, regeneration dpf, rail pressure sensor, turbo...Thanks for information.
November 27Nov 27 Sounds like the new settings need to be programmed in - e.g. new DPF,etc base readings
November 30Nov 30 Author In diagnostic, "Consult" for Nissan?I tryed... and nothing, Dealer Nissan and nothing.Car is normally go, but maybe I listening turbo pressure up\down.Blick red error of motor and car is normally go, but pressure is normal at now.I Stop the car and again start the motor, and error is resset some kilometrs. Insane car... realy
December 1Dec 1 Here is some more information on the fault and a video showing how to fix it (Google AI search of fault code P0002)P0002 is an OBD-II diagnostic trouble code for a fuel volume regulator control circuit range/performance issue, indicating the engine control unit (ECU) has detected a problem with the fuel volume regulator. This can be caused by a faulty fuel pump, regulator, or a problem with wiring, connectors, or a clogged fuel filter. Symptoms often include a illuminated check engine light, poor engine performance, and the vehicle entering "limp mode".
