PATRICK CONWAY
  1. PATRICK CONWAY changed their profile photo
  2. Brand new Nissan front brake discs. There were purchased a couple of years ago and stored in the shed since, they are in immaculate condition as they are still in the box, but the box is looking worse for wear as it has been stored in the shed, there is absolutely no wear on these. So grab a bargain at a snip of the car parts retailers prices. They are coming up as Quinton Hazell on net search after entering the number on the box. Technical Specification SKU: 136749_GEN_GB Manufacturer Part Number: BDC4850 Brand: Quinton Hazell Bolt Hole Circle Ø [mm]: 114,3 Brake Disc Thickness [mm]: 22 Number of Holes: 4 Fitting Position: Front Axle Height [mm]: 49,5 Brake Disc Type: Internally Vented Diameter [mm]: 280 Minimum Thickness [mm]: 20 Hub Bore Ø [mm]: 68 Brake System: Sumitomo Price is 20 pound, delivery will be extra on top of this of course, I am located in the Republic of Ireland.
  3. Hi there I am selling a brand new set of Nissan Almera brake shoes (4 PCS) for the Almeras listed below, unused in original box and never fitted. I would advise any potential purchaser to check item compatibility with original manufacturers part numbers to avoid confusion. Part Number SHU664 90R01433/8279 USE BRAKE SHOE FITTING KIT: 986 IF NOT REUSING OLD ONES Make Nissan Model Description Almera 1.5 Model Range Almera [00-06] Year 3/2000-6/2006 Note1 [N16] Size 203.2 x 37 mm Fitting Position: Rear Product Description Apec Brake Shoes Can send via delivery service too. Thanks for looking. 15 pound, delivery will be extra. I am located in the Republic of Ireland.
