x19apm
  1. Hi Trevor Do you know how to remover in instrument cover ? There are no signs of any fixings, Its likely that its this cover that is causing the noise :) Thanks
  2. Hey Guys I have a 2015 Qashqai, theres an annoying rattle / squeak coming from around the instrument cluster where the rev counter etc is located. When the noise starts if you hold the cluster / dash area it stops it so I'm assuming its something to do with plastic on plastic in that area. I was going to remove the instrument cluster and put some foam tape around th areas that touch but there is no obvious fixings in that area. Any one had the instrument cluster out ? Thanks
