ShujaAhmad2004
  1. Thanks for the reply Trevor. The issue I have is that I've found several links & videos showing me how to re-code the fob for a Nissan note BUT it's for the US version for the car (lock buttons in different position, etc). So I would have thought there would be an equivalent for the European version of the car too but I'm having no luck finding this. As a last resort, I'll probably have to pop down to the local dealers and get them to re-code the fob. But if anyone does have a suggestion or a sequence they think might work then please let me know. Thanks, Shuja
  2. Hi, I have recently purchased a Nissan Note N-Tec 1.4 (2011 Reg) and was only given 1 key with this. I decided to purchase another key online as a spare. I purchased a used original Nissan Note key, the same as the one I already have. I was aware that the new key would have to have a new blade cut and the transponder recoded by an auto locksmith. However, I was under the impression that the FOB on the key could be reprogrammed/recoded so that the central locking system could be activated via the FOB buttons. Normally, there is a sequence of steps which initiate a programming mode in a car. I have come across a couple of these sequences for Nissan cars but they haven't worked for my Note (one was a sequence to enter your key in and out of the ignition 6 times but this seemed specific for US cars and didn't work for me, the other was a sequence to turn the ignition to the on position 6 times but this didn't work either - there were more steps in both sequences but, as they didn't work, I didn't think it was worth outlining the full details here). I tried the sequences several times but neither managed to activate any kind of programming mode. There must be a sequence that works for a UK/European version of the Nissan Note 2011 reg in order to recode your fob. Would anyone happen to know if there is such a sequence available? Regards, Shuja
  3. Hi, Just wanted to say hello after joining the club. Recently purchased a Nissan Note N-Tec 2011 petrol. Shuja
