Shipdenborn
  1. Thank you for responding. I have disconnected the tube where it joins the line from he pump, and used compressed air on the jet nozzle. But it made no diffeence, sadly. So far I have been unable to remove the wiper arms. So have used wd40 in the hope this will free them up. Fingers crossed. Gerald
  2. Thank you for replying. I have managed to get a 15amp fuse wire down 46cm. However the line is still blocked/crimped. I have uncoupled the pipe join between the pump and the windscreen washers - that pumps very well. Also when reconnected, the driver's side washer works. Is it possible to remove the outlets and work on the hose line, on the passenger side? Failing that, how dow I remove the shroud which holds the w/screen outlets and the wiper blades? I have attached some photos which I hope will help. Thank you agaain for replying. Best Wishes
  3. How do I remove the panel in which the nozzles are fitted. It is the passenger side nozzle. Type is E11*2001...........*06. First registered Dec 2009
