Project Moff - 600BHP R33 GTS-t Skyline
FULL BLOG CAN BE FOUND HERE - The Project Moff Race Car
Hiya All,
I'm new, thought I would start a thread.. :)
Here is a bit about the car..
Its an R33 GTS-t Spec 2... I transplanted an RB26 R32 GTR Engine in, added a
Garret 4094R Turbo. the car has a huge spec list, with plenty of updates to
come...
Lots more to come, but for now, here is a piccy...
http://www.theprojectmoff.co.uk/images_temp/809/5246888/41018.9050810185/800/0/FFFFFF/0/brands-hatch-170412.jpg
  • Replies 82
  • Views 33.5k
  • Created
  • Last Reply
Top Posters In This Topic
  • Author
Updated spec list .. :)
Engine
•RB26 Red painted engine (from an R32 GTR)
•Garret 4094R Turbo (Oil and Water Cooled)
•HKS F Con Pro Gold Ecu (version 3.2)
•Wossner Pistons
•PEC Rods
•ACL Race Bearings
•Stage 1 Abbey Motorsport modified Head
•HKS Camshaft 264 Duration - 10.0mm Lift - Inlet
•HKS Camshafts 272 Duration -10.2mm Lift - Exhaust.
•Balanced Crank, flywheel, front pulley
•Top Mount Manifold
•Denso 720cc injectors
•HKS Oil pump
•N1 Water Pump
•HKS Gaskets and seals
•HKS Triple plate clutch
•Greddy External wastegate
•Trust 100mm FMIC
•Mocal 34 Row Oil Cooler
•50mm Japspeed Radiator
•Nismo Fuel Pump
•Splitfire Coil Packs
•Rips modified GTR sump, with diff removed, welded, extended and baffled
•Cold start system removed
•Cabin heating systems removed from engine
•Tomei Fuel Rail
•R34 GTR Engine Loom
•Greddy EGT Gauge
•Greddy Profec B Boost controller
•HKS Hard Pipe Kit
•HKS Induction Kit
•Air Con Removed
•Carbon Canistor Removed
•RB25DET Gearbox
•Front & Rear Strut brace
Exhaust
•Japspeed De-Cat
•Japspeed Turbo Elbow
•V-Band 80mm Downpipe
Japspeed spec 1 cat back exhaust
Drivetrain
•Heavy Shockproof Gear Oil
•Silkolene Diff Oil
•Nismo Pro S 1.5 Way Rear Diff with extended cooling fins
HKS Triple plate Clutch
Suspension
•Driftworks Rear Camber and Caster Arms
•Cusco Front Camber Arms
•Polished Stainless Hicas Lock Bar
•Driftworks Front Tie Rods
•Tein Track Rod Ends
•Tein Track Rods
•Poly Subframe Bushes
•Driftworks Rear Traction Arms
•Ohlin Coilovers (Rebuilt to full track spec)
Exterior
•Full Respray (coming soon)
•Nismo Bodykit
•Custom front Splitter
•Carbon Nismo 'B' Pillars
•Custom made Carbon Kevlar bonnet
•Custom Carbon Kevlar wider front wings
•Carbon Rear Boot
•Carbon Rear adjustable Spolier
•Custom Sand Blasted, etched and powder Coated front and rear subframes
•Dual HID's 600k 55w. Main and Dipped Beam
Interior
•Tinted Windows
•Corbeau Evolution Carbon Kevlar Drivers Seat
•Aftermarket Racing Steering Wheel
•Apexi Dual Turbo timer
•Greddy Profec B2 Boost Controller
•Stripped Interior
HKS Boost Guage
•2 x 3" 4 Point EJS Racing Harnesses
•Andy Robinson FIA Approved 7 point Roll Cage with Door Bars
•Greddy 60mm EGT Gauge
•Greddy 60mm Oil temp Guage
•Greddy 60mm Oil pressure Guage
•Stack Water Temp Gauge
•Carbon Door Cards
Brakes
•Nismo Steel Brake lines
•Stoptech 355mm Front and Rear Discs with Aluminium Hubs
•Stoptech 6 Pot Front Calipers
•Stoptech 4 Pot Rear Calipers
•DS3000 Pads
•Custom Moff made brake stopper
•RBF600 Racing Brake Fluid
Wheels & Tyres
•18 x 11J Rota MXR Rear
•18 x 10J Rota MXR Front
•Toyo 888's 315/30/18 Rear
•Toyo 888's 265/35/18 Fronts
  • Author
After we were happy with the mock up of the new rear wider arches, its was time to make a start with fitting...
Out came the Angle grinder
This is the car lowered back to the floor, as you can see we have plenty of room. This is an 11J rear wheel
The next step will be to make up a lip for the new rear arch to sit on, as well as to join the 2 skins back together...
Full details can be read on the site of course...  http://www.theprojectmoff.co.uk/19-march-2013.5483995.cms
Lots more to come...
  • Author
Now that we had cut the arches out to allow for more room, we had to weld the 2 skins back together.
This would do a number of things :
Put strength back into the arches
Stop water getting back up into the arches and rusting
Give us a mounting point for the new arches
We started by tacking pices of metal in place.
More info on the blog... http://www.theprojectmoff.co.uk/26-march-2013.5484293.cms'>Project Moff Blog
  https://www.facebook.com/themoffshop'>Project Moff on Facebook
Loads more to come...
  • Author
some good Progress
New rear arches are on .. The Wheels on the back, don't forget are 11J Wide !!!
Next the caris of To Abbey Motorsport to go on their Dyna Pack Dyno, some suspension work, and Race Prep
http://www.theprojectmoff.co.uk/12-april-2013.5484423.cms
Things are now really starting to hot up...
  • Author
Here are some photos of the new rear arches. Believe it or not, we actually sprayed the rear arches using nothing more than black spray cans... This is only temporary until the car goes in for a respray.
The wheels on the car are spare wheels until the race wheels are fitted..
The Car is now off to Abbey Motorsport in Surrey, who will be putting the car on their Dynapack Dyno, setting up the Suspension and some other Race prep..
More details on the blog.. http://www.theprojectmoff.co.uk/25-april---arches-done-off-to-abbey-motorsport.5484935.cms
  • Author
Project Moff is now at www.abbeymotorsport.co.uk.
After a quick look over the car, they noticed the exhaust manifold is cracked
and urgently need of repair. Its going to be removed and hopefully welded up.
They are extremely busy, but have managed to find the time for this
additional work, great stuff... :)
More updates soon....
  • Author
Wow, huge thank sto the guys at Abbey Motorsport...
Project Moff managed 605 BHP at the hubs, which is more power than before, and at less boooooost...
Great results, dyno charts to follow...
RWD only, this is going to be fun... !!!!
  • Author
Here are the dyno results...
The previous time Mark @ Abbey Motorsport had the car on the Dyno, at 1.5 Bar, the car was producing 594 BHP ATH.
We the changes and improvements we made, he managed to bring the boost in a little earlier, and at 1.4 Bar,
we now have 605 BHP ATH, and what should be a more driveable car too...
Here is the Dyno Graph
For the other dyno sheets, and a comparison of the last ones, for you real geeks, please see :
  • Author
Ok, we have been a bit busy !
Lots has been done, read the full update on the blog, linky below... :)
Time to load up and get to Snetterton next, where the drivers view will be like this (well, it will have a steering wheel)
  • 2 weeks later...
  • Author
Well, what a day...
We managed to end up in 3rd position in the final, and were also faster than the previous club record set in 2011... (guy in first place now holds it, as he was first, but just goes to show how quick the final was)
Photos and more details to follow soon... :)
  • 2 weeks later...
  • Author
Full Write up of the event, along with photos and videos coming very soon..
If you would like to follow the Facebook page for Project Moff, please do :)
  • Author
Great Pic from Rich Sams
  • Author
Ooooooh, Time Attack put us on their website... :)
  • 3 weeks later...
  • Author
Engine
Wossner Pistons
PEC Rods
ACL Race Bearings
Top Mount Manifold
HKS Oil pump
N1 Water Pump
Trust 100mm FMIC
Nismo Fuel Pump
Greddy Fuel Rail
R34 GTR Engine Loom
Greddy EGT Gauge
HKS Hard Pipe Kit
K&N Super Huge 100mm intake Filter
Air Con Removed
RB25DET Gearbox
Vibratechnics Custom Race Engine Mounts
Exhaust
Japspeed Silenced De-Cat
V-Band 80mm Turbo Elbow & Downpipe
Drivetrain
Silkolene Diff Oil
Suspension
Cusco Front Strut Brace
Cusco Rear Strut Brace
Tein Track Rod Ends
Tein Track Rods
Exterior
Nismo Bodykit
Carbon Rear Boot
Interior
Tinted Windows
Sparco Formula D Suede Steering Wheel
Snap off Steering boss kit
Extended steering boss
Stripped Interior
HKS Boost Guage
Carbon Door Cards
Brakes
DS3000 Pads
Wheels & Tyres
18 x 11J Rota MXR Rear ET+8
18 x 10J Rota MXR Front ET+12
Toyo 888's 265/30/18 Rear
Power
At 1.4 Bar Turbo Boost pressure
Peak Power 605 BHP @ 7816 Revs @ Hubs
Peak Torque 445 lb/ft @ 6310 Revs @ Hubs
  • 2 months later...
  • 2 months later...
  • Author
Been a little while since the last update. We are working on
a few exciting plans to take place in early 2014...
Will be sharing with all once its all confirmed.. :)
  • 1 month later...
  • Author
Hiya All,
Sorry for a delay in updating....
The car is now back with Abbey Motorsport for a little bit of work.
Dyno Run - Bit of a health check to make sure car is performing ok
Suspension alignment - Abbey have a new hunter 4 wheel alignment and geometry set up tool which was recently installed.
Service - Change all the fluids....
Few other bits... :)
Keep you posted...
  • 3 weeks later...
  • Author
This Sunday we are set to go to Silverstone F1 Circuit for the day, weather looks like there is a chance of rain, but fingers crossed...
The Go Pro is charged, so lots of video and photos to come... :)
  • Author
Here is the Dyno run from Abbey Motorsport the other day.
BHP figure is on the right middle (618 at the hubs)
Lb/ft is on the left middle (divided by Diff Ratio which is 4.111:1, giving about 475 lb/ft)
Its maxing out the injectors, so has been set back a little form this run
Weather is looking like it might be dry, I can't wait for this Sunday !!!
  • 2 weeks later...
  • Author
We had a cracking day out at Silverstone on Sunday 9th March with Abbey Motorsport
and their crew. Quite a few Abbey customers too. The weather was fantastic.
Photos and videos to come...
