Posted January 9, 20187 yr Hi, im in a process of purchasing a hardbody D/C 2008 with 180 000mileage (2,4 petrol) what do I need to take note of or take special attention to?
January 10, 20187 yr I would thoroughly check the chassis for corrosion as the equivalent Navara suffers from the chassis corroding and snapping just behind the rear bulkhead.
March 20, 20187 yr I would suggest a chassis inspection as we own a Navara 2007 which failed chassis inspection and is currently in Spain being repaired. Also have Pathfinder 2007 which also failed the inspection and has been written off by Nissan!
March 21, 20187 yr 19 hours ago, Helen1976 said: I would suggest a chassis inspection as we own a Navara 2007 which failed chassis inspection and is currently in Spain being repaired. Also have Pathfinder 2007 which also failed the inspection and has been written off by Nissan! Not good news then....such good trucks but let down by chassis corrosion
