GA14De limiter
For oval racing we have a sunny with an GA14De engine. monopoint injection.
Just before the corner the limiter kicks in at 6900rpm.
Is there a way to delete the limiter of make it a little bit higher so we can hit te corner without hitting te limiter?
There's no real ecu so it must be something with the distributor or something like that.
Thanks
jouri
Hi Jouri
From memory it may be limited by a centrifugal weight which throws out at a predetermined rotational speed which then shorts out to earth to cut the spark until it drops back again...I'm sure they used this on Toyota around the same time so may be the same for the Nissan.
Would be interesting to find out....only way is to strip the distributor down to investigate
Cheers   Trevor
  • Author
Thx Trevor!
I'll have a look next weekend.
kr
Jouri
