April 7, 20187 yr Hi all. I have just got a Nissan Juke and wanted to use my roof rack on it. Halford say all I need is a different fitting kit, which I have ordered. I am a little concerned that the fitting kit which tightens underneath the rim of the door is going to scratch the paintwork. Has anyone fitted a roof rack to their Juke? How did it go and do the fitting protect the paintwork or scratch it?
April 10, 20187 yr They usually have rubber padding which compresses and grips....it shouldn't scratch the paintwork in normal operation....just ensure it is tight enough so it doesn't move around
April 22, 20187 yr Before you fit it, make sure you clean all contact areas as it’s often overlooked and causes scratches.
