Start /stop / nightmare
Just brought the limited editions  1.3 Nissan qashqai
had it 6 days and drove it 3 times to work then to find last night wouldn’t start
Rac - 3hr wait
then by a Miracle 30 mins later I dipped the clutch and pressed the start button and it started
rang dealership and she said unless I Had pressed the start then the clutch  In the end  I was pressing everything
Been out all day today and it’s been ok
but I taking it to Nissan on Monday for them to recheck it
any body had the same issues I only ever had manual normal  car with keys
so this is taking some getting use to and using the electric brake
but I am getting better
any top tips off anyone
Hi Dawn.
I also fell foul to the same issue recently, albeit I knew I had to dip the clutch pedal but I hadn't pressed it down far enough (only by a fraction) which was enough for it not to start.
I then altered the seat setting a little closer and this resolved the issue.
It does take a bit of getting used to and also the handbrake can be daunting until familiar with it.
  • Author
At least I don’t feel so bad know I thought the car was playing up I any had it 6 days many thanks 😊
  • 3 months later...
Morning Dawn
Push the clutch all the way down, put the key fob on the start button & then push the fob against the button, there is a sensor in the fob that recognise the car & will even start it if the battery in the fob is dead,
I have looked at every possibility on line/ you tub because I have a Quashqui that has had 4 flat batteries in 8 months,!, hope this helps & you don't end up like me,
Good luck
Tina 😊
