Rear door won’t open from outside
My pathfinder has an issue with one of the rear doors, I can open it from inside but not outside, the handle moves but doesn’t,t open the door, the outside handle has been replaced as well as the inside handle but it hasn’t worked. To make matters worse I have just put the child lock on so can’t even open the door from inside ☹️ Has anyone got any ideas ?
Hi Deb.....welcome to the Forums
That's a tough one as you would have to remove the door card in situ which can be done but is fiddly and you may damaged some trim parts.
I cannot think of any other way to get around it though
