qashqai j10 front subframe
Re: 1.5 DCI 2007 qashqai
I'm looking for front subframe and reading somewhere they are different for the dpf and non-dpf models.... is that right? I see the dpf model has a bracket at the rear (presumably a mount bracket for the exhaust system)...
So if they are different, is it just the bracket or is there a fundamental difference? Or can they be interchanged? Ie a dpf one fitted to the earlier non dpf?
  • 2 weeks later...
