December 22, 20223 yr Hi all, I’ve just bought a Nissan Leaf 62kw e+ Tekna. It was first registered on 31/12/2020. When I go into reverse it doesn’t make a reversing noise (that annoying sound so many people seem to want rid of). Im a taxi driver and would actually prefer to have the reversing sound. Can anyone tell me as to whether or not my car should omit the reversing noise or not. I was under the impression that all Leaf’s did. I look forward to your replies. Cheers David😄
December 28, 20223 yr It may be that the previous owner had the function switched off You could ask the dealer to reinstall the function via the scan tool but this would cost Chances are it has LED lighting, if not then I would fit a bulb with a reverse beeper built in https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2499334.m570.l1313&_nkw=reverse+light+bulb+with+beeper&_sacat=131090
February 15, 20232 yr This post was recognized by Trevor! steve morley was awarded the badge 'Helpful' and 30 points. Hi I have a 71 plate leaf I have had my sounder switch on/off sticking in I give it a bit WD40 and had know probs since
