Airbag light
Hi I purchased a Qashqai  2017 a year ago.
It is still under warranty.
The red airbag light comes on every time there is a frost.
The garage have suggested its because the battery dips in power when there is a frost.
Although 4 months ago I had to have a new battery when it was flat.
It now needs a mot, obviously it will fail with the light on again.
It costs £100 to clear the fault.
Any advice greatly appreciated.
  • 2 weeks later...
Sounds more like a connector to the seat belt pretensioners under the seat.
Try moving the seat to a different position with the ignition off and then switch the ignition on to see if it has cleared.
If so the its the connectors under the seat
