Hi all , new to site so hope I’m posting this in the right place .😁
purchased a pathfinder approx 7 months ago and getting to grips with the electrical problems.
changed the clock spring recently so horn now working . However air bag light still flashes 1 long and 7 short.
purchased a srs code reader and have B 1059 code which cannot be erased!
drivers seat belt doesn’t retract properly so I wonder if this is the issue ? Possibly an open circuit ?
my question is if I pull the connector can I link the seat belt terminals with a resistor to confirm that this is the problem ie allows a reset if so what size ? Or if anyone can offer some other ideas to resolve .
Thanks
  • 3 weeks later...
I would check the connections under the seats (ignition off) and see if secure or damaged in any way
You could use a resistor to see if that works but do not apply resistance checks to the SRS components (airbags, pretensioners, etc)
If the vehicle has been in a crash and the airbag module has sensed this then you will need to replace the module but believe a secondhand one should work straight away and cancel the code
