Steering Wheel Squeak
Hello,
I wonder if anyone has had the same issue as me.
The steering emits a squeak when it there is moisture in the air, so during the warm months since I got the car in June, no noise at all.
You can imagine what it has been like recently since it has been raining....
The forecourt I bought the car from has there own garage and they apparently have greased the steering joint, both side since they replaced the gearbox (under warranty)
I am going back to them with this continuing issue, but I wanted to see if anyone on here has had the same issue and what it was?
Thanks.
  • Author
Thank you for the explanation.
What can I do about this. Is there something that needs replacing?
Personally I would direct compressed air around the area to see if I could clean it without removing components - you can get compressed air canisters to clean computers and keyboards.
The possibly I would lightly apply some silicone spray around the area the noise is coming from but not too much, only a fine spray so as not to interfere with the SRS components.
  • 2 months later...
  • Author
UPDATE
So it appears we may have FINALLY sorted this issue.
It seems it was the suspension top mount.
There was play in the mount as they showed me after they replaced it.
So far so good, no noise. I will update further if it come back.
