good morning
Usually you would need to have a scan tool to scan the faults. There maybe a way to do this manually, but I dont have a leaf to test this on.
Sit in the driver seat (car OFF).
  1. Press and hold the trip reset button on the dash.
  2. While holding it, press the Power button twice (don’t press the brake).
  3. Keep holding until the dash flashes and displays “DIAG” or icons.
  4. Release the button.
  5. Press the trip button again to scroll through system checks.
If you only see “---” or no data, you’ll need a scan tool for detailed fault codes.
Give that a go. But i am no expert so if you get no joy then have this inspected by a dealer.
