CliveS
  1. CliveS joined the community
  2. There is a connection in the pixo between the drivers seat belt switch and the airbag light which sometimes causes problems and requires you to fiddle with the under seat wiring to make sure the plug/socket connection is good. My airbag light is still on after mending the 3 wire clock spring cable which had a low resistance in one of the connection plugs. Anybody know where the actuator collision relay is hidden as can't see it anywhere. There is a electronic control box up under the dash board above the foot brake pedal which maybe causing a problem?? CliveS
