Badd bazz
  1. Avoid cvt auto gearbox models like the plague the later dct box is far more reliable and less probe to failure at relativley low mileages cvt gearbox are bad news
  2. The newer engine is the same one used in the A,class mercedes comes in two power outputs 130 bhp and 160 bhp it dosnt suffer the 1.2 engines well documented timing chain and excessive oil consumption issues i found mpg on the 130 bhp model to be about the same as my 1.2 qasqaui when i had one for a week as a courtesy vehicle , also the engine is not as smooth as the 1.2 unit and seems to have flat spots , occasional hesitancy whilst driving at lower speeds
  3. Was the battery the correct ampage and also an agm one you fitted are there any dash light warning showing apart from stop start ?
  4. Have just had to deal twice with foxes chewing through abs cables to the rear wheels of my qasqai first repair at nissan dealers who charged 270 quid to repair cable and then cover it in grease the second repair to the opposite sides cable that nissan failed to grease whilst doing the first cable auto electrician repair to cable 90 quid when it happens hill start assist , cruise , stop start are all disabled till its repaired Apparently cable insulation is a soy based one that nissan use is there a better permanent solution to this problem than greasing all the cables under the car ???
