  2. Not entirely sure but I have only ever encountered a few methods of retaining the gear knob. Grub screw (usually small and hidden underneath the knob, screwed thread (twist off), detent clip (needs pulling up with force) - beyond that I'm not sure. I would start with trying to locate the grub screw, if not then gently try twisting anticlockwise, then if no joy then try knocking it upwards (I tend to hold onto the gear knob and with your other hand wallop your gripping hand to force it up. Beware to keep you face out of the way :-)
  3. I think you have the correct diagnostic procedure for ascertaining the fault(s) but maybe take a step back and diagnose each code, warning lamp and issue individually. Reason being there could be one overriding fault that is causing it or there could be a couple of faults present.
  4. If you would like to wrapped them with gaffer tape to give more support to the hoses and then evaluate if there is an improvement in the performance then you can decide it the hoses need replacement
  5. Hi Jeannie Does the sunroof sit and seal properly, no leaks? Open it right up and cleack for dirt, leaves, clean it out. Clean the rubber seals with a bit of wd40 or silicon just to make sure it sits properly. Also check the paintork to make sure the sunroof os not fowling the paintwork. May be touching as the car is flexing when moving. So, check there is no loose cabled, or anything dropped around the back, get a torch and take a look.
  6. Welcome to the Nissan Owners Club!! @mrjhwinter
  7. Yesterday
  8. Cheers for this
  9. They get to a stage when they are worn out and worth replacing with an aftermarket system. Take a look in Halfords to see what aftermarket audio systems they have which should fit your existing radio slot
  10. If it is 'clacking' as you turn to a sharp left or right turn then it does suggest that the joint is worn. What else makes you think you have a problem with the joint?
  11. Last week
  12. I would be very tempted to take it back to the dealership and ask them to explain it to you - not only is it from the Nissan dealership so they should be well informed of any procedures and also the liability if there is any issues with the system. Please let us know how you get on with it
  13. Cheers thanks
  14. Hi, I would say Halfords but probably not on your model, I guess any decent independent mechanic should be able to change it. Not only is it the one lamp at the moment but they usually follow in pairs. I can recommend a mobile mechanic, Sam Mee who is top-drawer and would be able to do that job (assuming it doesn't need to be from underneath on a vehicle lift to access the bulb). Let me know if you want his number and I can PM it to you. Being based in Bournemouth myself I know many garages and some/most I would not advise going to but there are also a lot of very good garages and mechanics out there who are respectful of customers and their cars. (I know because I taught many of them over the years). Give me some garage names (best PM them to me) and can advise on their reputation as best I can. Cheers, Trevor
  15. how low was the warning down to? maybe less than a certain amount (e.g. zero or very low timeframe) and it won't reset unless through a scanner.
  16. Not sure to be honest but found this AI summary which could shine some light on your issue TSR Audible Warning Details: Speed Limit Change: A single chime sounds when the system detects a new speed limit sign. Overspeed Warning: If the vehicle exceeds the detected speed limit, the display flashes and a chime sounds four times. Customization: Within the [Driver Assistance] > [Traffic Sign Assist] menu, drivers can set the system to: [Warning]: Both visual speed limit display and audible overspeed chimes are active. [Info only]: Only the visual display is active; audible alerts for speed changes are disabled. Temporary Suspension: The chime can be temporarily muted by slowing down or using the steering wheel scroll dial.
  17. Abs
  18. welcome back john!
  19. Deutsch: Hallo, wie ich sehe habt ihr das selbe Problem wie ich, an meinem Quashkai j11 mit 1.33 Liter Benziner. Ich habe auch ein gerichtliches Gutachten, auf deutsch. Leider hat der Gutachter nicht genau sagen können, mit was der Schaden angefangen hat. Das Thermostat und das Gehäuse, die Kopfdichtung und der Flüssigkeitsströmungsbegrenzer sind defekt . Die Wasserpumpe war in Ordnung. Während der Fahrt, kam bei mir auch kein Warnsymbol am Display. Erst später, als ich schon mit dem Auto am Straßenrand stand. Der Motor hat sich fest gefressen und das Kühlwasser ist sofort entwichen. Erfahren habe ich auch, dass der Quashkai J11 keinen Sensor besitzt, der erkennen kann, wie viel Kühlmittelwasser noch während der Fart vorhanden ist. Dies hat der Gutachter schriftlich bewiesen. Und meine Abgassensoren, die normaler weiße auch eine Meldung zeigen sollten, haben beide eine Funktionsstörung gehabt, laut Lesegerät vom Gutachter. Also höchstwahrscheinlich sind die Kabeln wie bei einem anderen Nutzer weggeschmolzen. Habt ihr bereits welche Resultate erziehlen können? Habt ihr auch irgend etwas schriftliches, wie ein Gutachten ? Damit ich es dem Gericht vorweisen kann? Ich habe nämlich noch Garantie und Gewährleistung auf dieses Auto. English:Hello, I see you have the same problem as me with my Quashkai j11 with a 1.33-liter gasoline engine. I also have a court report in German. Unfortunately, the expert was unable to say exactly what caused the damage. The thermostat and housing, the head gasket, and the fluid flow restrictor are defective. The water pump was fine. While driving, no warning symbol appeared on the display. Only later, when I was already standing on the side of the road with the car. The engine seized up and the coolant immediately leaked out. I also learned that the Quashkai J11 does not have a sensor that can detect how much coolant is still available while driving. The expert proved this in writing. And my exhaust sensors, which should normally also display a message, both had a malfunction, according to the expert's reading device. So most likely, the cables melted away, as was the case with another user. Have you already achieved any results? Do you also have anything in writing, such as an expert opinion? So that I can present it to the court? I still have a warranty and guarantee on this car. Translated with DeepL.com (free version)
  20. Thank you so much for responding with the solution - I'm sure many members will benefit from your time in diagnosing and cost (albeit a cheap component) rather than replacing everything in a process of elimination.
  21. Earlier
  22. Can't say that I have noticed exhaust pipes being this colour except for when engine oil has been sprayed over the exhaust and stained it
  23. The oil level sensor should be on the sump and as long as you have topped it up on a level surface then it should give a true reading - it may be worth checking the connection to the sensor and ensure not contaminated with water, corrosion, mud, etc
  24. Not sure as the car is quite new so unless something has damaged the reservoir bottle or a hose has come detached ?
  25. Thanks for the update chris!!
  26. Yeah Trevor I generally get 3 months warranty out but with this being a newish car they gave 2 years for the price of 1
  27. I would read reviews of different independent garages on Trustpilot and then narrow down to one you think you can trust (not always the cheapest one)
  28. Is the engine petrol or diesel ? Turbocharged?
  29. I guess it depends what the load is in the back - loose rubble or large (but lightweight) objects. Ultimately, the brakes will adjust on the rear to how much load is being carried but the tyres will only ever be suitable to certain speeds and loads. I always work on the principle of driving the appropriate speed for the roads and conditions.
