	Thermostat housing failed leading to engine failuresublow40 replied to CFH's topic in Qashqai Club's Topics So, a little update on ours! We've managed to get a warranty replacement agreed via Ancaster and Nissan UK. We had to prove service history and it's going to take 6-8 weeks because there's a part out of stock (they've already had it 6 weeks). It took some arguing but definitely worth pursuing, especially if you've maintained your vehicle.
- 7 replies
	  Nissan President 1994 with ACTSUS hydraulic systemTrevor replied to Jarek's topic in General Nissan Owners Lounge You may be able to get the spheres re-gassed.....you could do on the Citroen and Hydrolastic spheres many years ago - look up Sphere repairs or regas
