  2. Hello I am looking for a Nissan SD25 Diesil engine which is out of a Nissan 20 Forklift. I am told the same engine was used in Nissan Cabstar and Nissan Bluebird vehicles in the 1980s. Our currant engine has a hole in the block so I am looking for a good block or a complete engine. Many thanks Colin
  4. I would definitely advise to return the car to the garage who fitted the clutch for them to diagnose the issue - could be an adjustment required or a faulty part, etc?
  5. Earlier
  6. Hi - welcome to the Club Fine looking Juke, not so sure I would manage to keep that paintwork clean all the time 🙂 Good to have you onboard!
  7. Make sure all sensors on the grill and windscreen areas are clean as dirt obscuring the sensors can result in this occuring
  8. Hi Lewis - welcome to the club Looks like a good spec Navara Major thing to have checked is the chassis for corrosion or cracks and believe the dealers have a recall and modified brackets to weld in (if it hasn't already been done)
  9. Hi Trevor - welcome to the club good to have you onboard and enjoy your Qashqai 🙂
  10. Hi guys n gals Has anyone attempted to retro fit roof rails to a 2022 model ?
  11. I'm having trouble finding the front turn signal (original two-phase) on the left side of the Nissan Pathfinder 2002, does anyone know where to buy one?
  13. I had the 1 litre engine in my last Juke. Its turbocharged so there is no loss of power. I now have a 1.6 Hybrid which is more cost effective especially around urban areas.
  14. I have a 2019 xtrail t32 2019 tekna and looking to put in a viofo dashcam with parking mod and hardwire it in does any one what fuse to plug in for permanent power when car is park and fuse when car is running
  15. I've been re-bushing the suspension on my Sunny Coupe and dicovered how rusty the brake splash shields are but I cannot find replacments. Do you know of someone who might have them?
  16. I would say it is more likely to be a gummed up turbo vanes fault which can be rectified by cleaning the turbo with a specialist cleaning solution (link below) https://www.ebay.co.uk/itm/292493130747?_skw=turbo+cleaner&itmmeta=01JTSXMZ9VE9ZW9F2H1DCM6423&hash=item4419f2fbfb%3Ag%3Ab9sAAOSwYutasp0A&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1fpV%2F8bmO6dppPkpUyUyyrTVatA%2BtxVHfyIQW%2BFrQfBfOZwB9GXDgirF%2FZx1wYQ5QWHnndTFW8dxHQnQwE2DJPM593%2FytgJBS5MLBDp8GWH%2FZutClKfIZWQSfoKddANZ7zaeBnZAo6VVmNaP6AcQjlZrAqIw0vsohppQpa1TRGcxd4sUcRwemDzU%2FgJBiFCwMC0j2OXXqnhoSWOhG9lxLcC0VLM4FFWpJ0NKLa%2FFsrMcFmbgwWZs209wAa7IvVnY8g%3D|tkp%3ABlBMUIL1073WZQ&keyword=turbo+cleaner&sacat=0&relatedSearch=true Once you have cleaned it and the vanes are free to move then a good italian tune-up should blast out any residue and carbon and should then run smoothly
  17. I would say that is an air conditioning system sensor - possibly system pressure sensor?
  18. okay, best bet really.....let us know how you get on with it
  19. Hi .... and welcome to the Club Great to have you onboard and feel free to post and answer any questions you feel able to answer. The Juke is a great car, my wife has one and just keeps going with minimal repairs (if any) but always maintained to keep it reliable.
  20. Here's a problem to bake your noodle. 1995 k11 Micra, not been driven for a month, 4 new problems have appeared, all lights. 1) left headlight not working. 2) left indicator telltale light not working, either in telltale or hazard mode, external lights all working and relay clicking. 3) handbrake warning light not working. 4) reversing light not working. I'm going to do all the usual checks, starting with the external bulbs, but these systems can't have anything in common, can they?
  21. What colour? there is a set of black seats on eBay at the min. item number is 316640688205
  22. It would seem, and I would wholeheartedly agree. Although, technically, you could leave all previous weights on a wheel for forever, and just keep balancing it with additional weights as necessary!??? 😂 Not the case here though. All the weights are fresh new. They put both push on weights and stick on weights. Push on weights went to the inside of each wheel. Stick on weights are to the outside behind the spokes on the aluminum mag wheels. And.. as stated.. opposite each other in three of the four, and about 2 hours on the clock location off opposite on the fourth. It’s very weird. I have personally balanced a lot of motorcycle wheels in my life.. and it’s always one weight.
  23. Thanks mate will do. Need to find a few bits and bobs but the car is mechanically sound.
  24. Thanks again. I’ve put in new batteries and tried the other fob for a while before. It is so random I am wondering if the door keyless buttons send a signal like the fob or they are hardwired. I’m thinking possibly the rf receiver is getting old and cranky like the rest of us….
  25. Hi....welcome to the Club
  26. Hi....welcome to the forum Good to have you onboard
