  2. Here is some more information on the fault and a video showing how to fix it (Google AI search of fault code P0002) P0002 is an OBD-II diagnostic trouble code for a fuel volume regulator control circuit range/performance issue, indicating the engine control unit (ECU) has detected a problem with the fuel volume regulator. This can be caused by a faulty fuel pump, regulator, or a problem with wiring, connectors, or a clogged fuel filter. Symptoms often include a illuminated check engine light, poor engine performance, and the vehicle entering "limp mode".
  4. Is there a known issue with 2010 Muranos that causes the front windows to lower without input?
  5. I am considering having a Topdon Carpal as my OBD diagnostic tool. Has anyone on this forum had any experience of this model?
  6. Can you turn of off the electric mirror fold , so is it possible to move them in/out manually ? So I can get the car in / out of the garage
  7. I don't have any faith whatsover with the current clowns in power so I wouldn't do anything hastily such as changing your car as it is always likely to change in the near future
  8. I have the joy of owning a 2014 Pathfinder with the CVT transmission. Was acting terrible, bad lurching, when shifting into D or reverse it would pause for about 5 seconds then grab. It also barelyl got to speed, so was a safety issue. After some research and error code P0776 Pressure Control Solonoid B, I replaced the valve body, with one off Amazon that in the description says "There is no software CD, itis installed directly" https://www.amazon.com/dp/B0FMFB9FVM?ref=ppx_yo2ov_dt_b_fed_asin_title Well after installing that with new CVT fluid, it has a very violent shake (judder maybe?) when starting to drive maybe 1 mph. New codes: P0746 Pressure Control solonoid A ( seems odd for a new valve body) P0847 Trans fluid pressure circuit b low (i would think this is on the valve body also) P084C Trans fluid pressure sensor H circuit Low, and using CVTx50 on a tablet, see the dreaded judder code: P17F0. So, I would like to know, is it mandatory to get a CD with a new valve body? Then how come several I have seen on Amazon and Ebay say it doesn't need one, or no mention at all? What about those decent reviews. It sounds like it is plug n play based on what I have seen so far. Yet on the other, need a CD, take to dealer $$$$. Can anyone please help me sort all this out?
  9. Which ‘control switch’?
  10. The dealership should walk you through the car if you have bought through them. Best to take someone along with you to aid your memory, I know because I get told things and promptly forget them :-)
  11. Its such a scam and see it all the time - easy money for the garages. It is possible to fit replacement rubbers if all they are is perished. As long as they are not perforated and leaking grease or if there is any play in the joints then it is perfectly serviceable. Advise on the MOT sheet but not necessary to replace otherwise. Recently fitted a replacement lower arm on wife's Juke and then replaced it a year later as the first (cheaper one) knocked the joint out in no time - more expensive one, quite a bit heavier duty for the N/S location and almost twice the weight. An easy job to carry out yourself and definitely not £1200 worth of repairs. Kept the old rubbers to use if necessary in the future. :-)
  12. Hi .... welcome to the Club Good to have you onboard
  13. Code p0111 relates to intake air temp sensor Put VW P0111 into google search and comes up with a few videos of location and replacement
  14. Earlier
  15. I'm sure you will keep finding bodges throughout the car and maybe worthwhile assuming everything needs checking and just work your way through it. If you are lucky you may find the issue which is causing the problems and may not cost you much if anything at all to resolve Let us know how you get on with it
  16. Please let us know how you get on with it
  17. Thanks. I’ll check it out
  18. Thanks all - found out extra security not needed. Closed topic
  19. Unless the chassis has been replaced as they suffered from the rear section (load area) breaking in half? https://www.google.com/search?client=safari&rls=en&q=nissan+navara+chassis&ie=UTF-8&oe=UTF-8 https://www.google.com/search?client=safari&rls=en&q=nissan+navara+chassis+number+location&ie=UTF-8&oe=UTF-8
  20. Well the induction hose you replaced was definitely the culprit and as that was perished I would also look for any other hoses that may have holes or splits through perishing over the years. An increase in revs is usually a vacuum leak through a perished or split hose. As for the transmission - it is hard to tell what the issue is but I would advise to get it to a transmission specialist for them to set it up correctly - may need calibration through specialist equipment
  21. Personally I would direct compressed air around the area to see if I could clean it without removing components - you can get compressed air canisters to clean computers and keyboards. The possibly I would lightly apply some silicone spray around the area the noise is coming from but not too much, only a fine spray so as not to interfere with the SRS components.
  22. Sometimes helps to breakdown carbon deposits but mainly using premium high octane/cetane fuels is best to help with cleaning up the combustion process.
  23. Hi...welcome to the Club Just do the bits that you can arrange to sort over time (wiper blades, tyres, etc) and just keep on top of servicing and any other issues that may crop up. Feel free to ask questions whenever you need advice
  24. I use a smart screen with Android Auto. Then connect my phone via BlueTooth and use Waze map. Less expensive and live updates of accidents, traffic jams etc.
  25. Hi All We can confirm our seasonal opening hours will be as follows: Up until the 19thDecember: Normal hours. Saturday 20th December: Closed Sunday 21st December: Closed Monday 22nd December: 9.00am – 3.00pm Tuesday 23rd December: 9.00am – 3.00pm Christmas Eve: 9.00am – 3.00pm Christmas Day: Closed Boxing Day: Closed Saturday 27th December: Closed Sunday 28th December: Closed Monday 29th December: 9.00am – 3.00pm Tuesday 30th December: 9.00am – 3.00pm New Years Eve: 9.00am – 3.00pm New Years Day: Closed Friday 2nd January: 9.00am – 3.00pm Saturday 3rd January: Normal Hours Resume. Regards, Dan
  26. I can only really find springs which will drop the height but not sure about other suspension components to complement the springs (dampers, links, etc) https://www.lkperformance.co.uk/car-parts/suspension/lowering-springs/nissan/pathfinder
  27. This is quite normal as it dims everything for nighttime driving. If you have the infotainment screen fitted then this also dims as well
