Hi all, just purchased a used Nissan Qashqai 1.2 dci tekna 5dr. I have yet to pick it up (tomorrow). Would anyone like to comment on this particular version please? (Good & bad :D)?
Thank you
Hi....welcome to the Club
Any ideas?
