  2. Hi ..... welcome to the Club It's a perfect car for local use more so than motorway but it should be mostly reliable and also economical Enjoy the forums
  3. It does sounds like a loose or worn belt but equally I have found so many of the new belts nowadays are more silicon based than rubber based compound. They slip for a past time until they get warm. Try to stick to genuine manufacture belt (avoid anything made in china) Check also the tensioner is okay and if worn then replace this at the same time
  4. Last week
  5. I bought this: Tuqiang Car Seat Covers For Nissan X- Trail 2014-20 5 Seat Full Set PU Leather but the purchase fell through so it is now up for sale. It is not used. It is listed on ebay https://www.ebay.co.uk/itm/297629455187
  6. I just tried taking down my spare tire to check the air pressure. Needless to say, I don't think it had ever been out. Due to the cold climate (Salted winter roads, Northern Canada), the bolt was very rusty and try as I might, no lube was enough and I snapped the bolt in the "hook" assembly that holds the spare tire carrier up under the car. Does anyone have a usable bolt and hook assembly that they'd be willing to sell?
  7. Earlier
  8. there are some posts on google search relating to the PO409 code I would first start by running some cleaning solution through the fuel and give the engine a very long high revs run to burn off any excess carbon that has collected in the EGR or Intake Manifold
  9. mostly timing chains are reliable if the correct servicing and maintenance is carried out when its specified and using quality oils and filters Please let us know how it goes !
  10. possibly air mass meter is causing the jerking - try removing, cleaning and replacing Another possible cause could be the throttle pedal sensor needs replacing? Have you turned off the air conditioning as this will run a fan on start up
  11. thanks for updating us and please let us know how it proceeds
  12. The Qashqais have only got the fuel flap protecting access to the fuel inlet. Is it possible to fit a locking fuel cap inside the body flap? If so anyone know of where to get one. please.
  13. Hallo den habe ich erfolgreich eingebaut: L7808 Spannungsregler 8V DC gruss Michael
  14. I would check the coolant pressure cap as my first point of call - replace if necessary as its quite cheap and take 30 seconds to do (only release the cap when the engine has cooled down)
  15. So, a little update on ours! We've managed to get a warranty replacement agreed via Ancaster and Nissan UK. We had to prove service history and it's going to take 6-8 weeks because there's a part out of stock (they've already had it 6 weeks). It took some arguing but definitely worth pursuing, especially if you've maintained your vehicle.
  16. Thanks. No instruction hadn't changed anything. Just did reset when it stopped working.
  17. Sounds like you have sorted it then - well done! You have done all the checks in the correct way and come to the right conclusion Only other thing maybe to recode the throttle body which was a thing on the slightly older Micra but may still apply A good scan tool should have this function on it
  18. You could try using different protocol settings on the scanners (if available) to read the codes
  19. You may be able to get the spheres re-gassed.....you could do on the Citroen and Hydrolastic spheres many years ago - look up Sphere repairs or regas
  20. Hi Stuart....welcome to the club I would say just have the vehicle checked over at a garage and if it is in need of a service to then have this carried out before venturing abroad. Also check your tyres for wear or damage and make sure all your lights are in working order. You may need to get vehicle passes such as Vignettes but otherwise, convert your headlamps so that the beam is deflected to the other side (can get a kit from Halfords for that). Good luck and enjoy your trip
  21. Sorry that no one responded to your post. One of the reasons on the old Micra 4 cylinder engine for poor idle was carbon build up in the throttle body. When it is cleaned out and refitted, you would then have to perform a reset on it through a diagnostic scan tool which should sort it
  22. When I had this i thought it was a phone or car setting. Can't really remember but I did get it to stop by altering which ever setting it was.
  23. The truck has been sold.
  24. My son is the proud new owner of a 2006 X-Trail T-30 as his first vehicle. Generally, it's in great condition, but it does need some bodywork to deal with rust. We are seeking recommendations on where to look online for replacement parts, ideally in Canada but open to internal suggestions. Specifically: Left Quarter Extension Left Quarter Reinforcement Thank you in advance for any advice or experiences.
  25. Firstly thanks to admin et all for the inclusion of your forum ...... Had a Navara some years back ... dreaded chassis issue and managed a buy back from Nissan Nordics as I live in Sweden. .. Just bought a 2018 NV300 and am trying to remove the drivers arm rest to fit an aftermarket seat cover... centre cap removed and a plastic long squared centre piece revealed.... any clue on how to remove please?... Have put grips on it and tried to ease it free and even put a shifter on it to hopefully slacken it off .... but to to avail ....any one had any experience with this that they could pass on valuable info? Thank you in advance Dox
  26. I would suspect it is the brake pads moving backwards and forwards - usually happens if the pads fitting kit is missing and allows the pads to move in the carrier. If it was the driveshaft joint then it would be constantly be clicking on acceleration and deceleration
  27. Did you resolve the issue? I was thinking it may be the Dual Mass Flywheel (if manual transmission) starting to break up Usually noticeable when switching the engine on/off when it will start to rattle
