  2. Hi everyone, I am Sid and I own a 1993 K reg 1.6 Sunny SR. Looking for a few bits and bobs and hopefully good advise. Thanks All.
  3. I own a 1.5dci Nissan pulsar 2015, and I want to change the CD player with a satnav unit. I was wondering if if anyone could help me find a wiring diagram for it as one of the original plugs doesn't fit into the new unit. I've had a look around and couldn't find one. Can anyone please help me?
  4. Hi enzso ....welcome to the club There is a reset procedure for the CVT transmission which may benefit you. CM (Transmission Control Module) reset by cycling the ignition and pressing the accelerator pedal, or disconnecting the battery. https://www.google.com/search?q=nissan+k13+automatic+gearbox+reset&rlz=1C5MACD_en&oq=nissan+k13+automatic+gearbox+reset&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigAdIBCTE0NzQ0ajBqN6gCALACAA&sourceid=chrome&ie=UTF-8 There are also videos on how to reset the transmission in this search link (above)
  6. Does anyone know where to find rear right door glass for 1984 n11 4door cherry? Help please
  7. OK, I've managed to sort it now.
  8. It's on my trailer. I want to get another as a spare wheel. Tyre size is 165 R13C. What car does it come off?
  9. Earlier
  10. In September 2024 I bought a brand-new Qashqai e-power when the weather went below 5° the car would not start the dashboard would not come on after many times trying to start it would eventually start one morning it would not start and my foot slipped off the break onto the accelerator and I could hear the engine come on but the dashboard remain off after going through five diagnostic checks and the dealer saying that there’s nothing wrong with the car eventually they decided after seven months to change the instrument panel on the dashboard now we have to wait till September October when the weather gets cold to see whether it worked or not I’m sure that i’m the only one that is experiencing is happening too
  11. Many thanks for this. Really helpful reply. Greg
  12. try Samco hoses - they are silicon and can be made to length and shape https://samcosport.com/car/
  13. I’m looking for a radiator for our scargo, damaged is ok providing the bottom tank is ok many thanks
  14. Hi all, I am the third owner of my 1994 Nissan Altima. I'm looking to get some help and advice on repairs that it needs. Can somebody point me in the right direction to which forum I would use I don't really see a Nissan Altima forum. Alternatively I could just say what's wrong with it here. I need to swap out the knock sensor and I'm not really sure how to get to it. If anybody knows the procedure I would be grateful. The knock sensor is behind the engine below the intake manifold.
  15. Hi all, I’m trying to replace the alternator on my 2017 Nissan Micra K14 Visia 1.0L (71PS – HR10DE engine), but I’ve hit a wall trying to get the belt off. I’ve located the tensioner pulley (the black one just above the alternator), but the centre is smooth — no bolt head or nut — and I can’t for the life of me find where to apply a tool to release the belt tension. I am no mechanic either .... wheels and fluids is usually my limit! I’ve checked above, behind, and around the tensioner pulley but can’t see a square hole or hex boss to rotate the tensioner arm. The engine bay is tight, and I’m not sure if I’m missing something obvious or if access is just that hidden. I’ve tried to follow online guides and videos, but most are for different engines or older models (K12/K13). Photos attached if that helps (can add more if needed). Any help — diagrams, tips, tooling advice — would be massively appreciated before I lose the will to live or call a mechanic 😅 Thanks in advance!
  16. Hi there, I have a 2022 Nissan Qashqai J12 Tekna (36 CAM, etc.), and my current display screen looks like this: [img]https://i.ibb.co/ZR3WXYr2/Screenshot-2025-06-19-at-11-48-41-Used-2022-BLUE-Nissan-Qashqai-1-3-Di-G-T-MH-158-Tekna-5dr-Xtronic.png[/img] I’m looking to upgrade it to this screen: [img]https://i.ibb.co/xZpfPGP/Screenshot-2025-06-19-at-11-48-30-Used-2022-GREY-Nissan-Qashqai-1-3-Di-G-T-MH-158-Tekna-5dr-Xtronic.png[/img] Can you confirm the following: Is this a direct plug-and-play swap? Will all existing cameras and sensors still function correctly? Is a PIN code or any additional programming required? Thanks in advance for your help! Best regards,
  17. thanks admin. I'll take some pics, and post later. Any views on the 1.2 engines?
  18. Welcome to the Club
  19. You should be able to find a set of halogen headlamps which are completely different to Xenon type Try Partsfinder or eBay to see if there is a pair for sale
  20. Hi folks. Im new to this, but im trying desperately to sell my 1989 silver nissan sunny. She's in good condition and has been garaged for 10 yrs. Iv had it from New, so one owner. She needs a service,MOT and taxed⁷. She's nearly 40yrs old and the milage is 130,000... shes an old lady with plenty of life her still. Thanks for readying my story.
  21. Hi all Had my 2015 qashqai tekna over a year now with 49000 miles and 1 garage vist for a snapped coil spring.lol
  22. Does anyone on here have one of these & want to tell me all about it please ??
  23. Hello, I’ve just joined and thank you. I’m from Aberdeenshire in the UK. I am getting a 2019 41k miles diesel Micra soon, the dealer says they will change the cambelt and give it a 6 year service. Does anybody know what should be getting done for that service? thank you Neil
  24. I have experienced something very similar. On researching a "fix" I found that holding down the central on/off/volume button for 10 seconds will reset the system.
  25. Has anyone else lost the back up alert sound? Camera works fine but lost alert sound.
  26. Morning all! I'm looking at replacing my disc and pads on my nissan pulsar. Could I ask if anyone has a pdf workshop manual or one they would recommend for changing brake disc and pads on a MK3 (2016) Nissan Pulsar?
  27. Afternoon all! I'm looking at replacing my disc and pads on my nissan pulsar. Could I ask if anyone has a pdf workshop manual or one they would recommend for changing brake disc and pads on a MK3 (2016) Nissan Pulsar?
  28. Hello , it has been awhile since last posting a/c stoped chilling and garage found small leak and sorted. But fitter said that the main radiator fan was not coming on and could cause problems with high temp /pressure in a/c system.cannot find anything about checking fan motor. Not a lot of space to access it . Does the fan have a fuse?
