  2. Rejection of car initiated but apparently this is a long process!
  3. Thanks all - found out extra security not needed. Closed topic
  4. Today
  5. Unless the chassis has been replaced as they suffered from the rear section (load area) breaking in half? https://www.google.com/search?client=safari&rls=en&q=nissan+navara+chassis&ie=UTF-8&oe=UTF-8 https://www.google.com/search?client=safari&rls=en&q=nissan+navara+chassis+number+location&ie=UTF-8&oe=UTF-8
  6. Sounds like the timing chain is worn - just posted an article relating to a Nissan Pulsar c13 1.2 DIG-T engine with same symptoms. https://www.nissanownersclub.com/forums/topic/34996-nissan-pulsar-c13-neverending-problem/
  7. Hmm, seems like someone had the issue before and a bodge was carried to rectify the issue (or at least attempt to rectify it). There is an issue with the timing chains and as far as I can see it was a recall from Nissan. It does suggest that it occurs on hard acceleration (e.g. from a slip-road) and if the chain is slack it can drift away from the timing point by a small fraction (much like a loose timing belt) which can then throw a code for cam/crank timing and result in what you are experiencing. I would personally replace the engine oil and look to see what has come out - e.g. metal particles and then replace it with the specified oil which may have not been supplied with previously. https://www.autodoc.co.uk/car-parts/engine-oil-12094/nissan/pulsar/pulsar-hatchback-c13/107484-1-2-dig-t If you use a quality oil of the correct specifications (as listed in the link above) and see if that makes any difference to how it runs. If no real difference is noted then I would advise to get the timing chain replaced which will almost certainly make a difference if it is worn
  8. Yesterday
  9. manze joined the community
  10. Hello, I recently purchased a 2016 (registration year) Nissan Pulsar C13 1.2L Petrol DIG-T. I bought this car from a private seller about a month ago and it drove lovely for almost two weeks and it's been nothing but problems ever since. First time I noticed the issue, I was taking an exit ramp off the M50 in gear 3 at about 45km/h when it wouldn't accelerate smoothly and jerked a bit. I thought nothing of it, then it did it again later on the N4 near Mullingar, Edgeworthstown and Longford. I had it checked 3 days later, just for fault codes and cylinder 3 showed misfires. The jerking kept getting worse and worse until eventually the check engine light would come on for prolonged periods and flash occasionally. I then brought it to a fancy garage where they did a compression test and all 4 cylinders are good but the spark plugs were mismatched, and the wiring loom was split. The wiring loom and connector for cylinder 3 had been tampered with and they were damaged, I assumed this was the root of the issue. The garage replaced all 4 spark plugs AND all 4 coils with OEM parts and their technician repaired the wiring loom and connector. I got the car back off them today, and it drove fine but only for about 15km before I noticed the same jerking issue mildly occuring again. it's not as bad as the day I took it to the mechanic, but it seems like its been reset to when the issue first started. I saw a post of some people buying this model and having to have the engine replaced entirely under warranty shortly after 2016 but this car has been in use before I bought it with frequently paid tax and NCT done every 2 years. Has anyone else had this issue, please for the love of god help me. The repairs that have been done weren't cheap and the problem is STILL here. I can't afford to sink more money into this car. please please please help
  11. Pulsar Owner joined the community
  12. Davez started following Engine noise
  13. When accelerating engine makes a clattering sound then returns to sounding normal
  14. Davez joined the community
  15. Sathish joined the community
  16. Plata900rr joined the community
  17. Last week
  18. Hi Trevor Thank for your reply but i have looked there and its not on it.
  19. It's on the chassis rail right hand side (outer) under the drivers door. Literally bend down and you should see it straight under the sill. Found this on a Navara site, also it should be on the body below the windscreen area but if all else fails it will be printed on your vehicle logbook
  20. Well the induction hose you replaced was definitely the culprit and as that was perished I would also look for any other hoses that may have holes or splits through perishing over the years. An increase in revs is usually a vacuum leak through a perished or split hose. As for the transmission - it is hard to tell what the issue is but I would advise to get it to a transmission specialist for them to set it up correctly - may need calibration through specialist equipment
  21. Hi Guys Looking for VIN number Location, I have the one on the windscreen and the one on the inside of the door, i have looked on the Chassis under neath as you open the driver's door,and its not there, is there any other place it can be? Your Help would be appreciated Thanks.
  22. 9006 joined the community
  23. I have a 2014 Nissan Pathfinder SL 3.5L V6. When my wife bought this in September 2025, it seemed fine at the time, no transmission or engine issues. She drove it home for 2.5 hours, then around town for a few days. I was out of town at this time, and she drove to pick me up, 3 hours each way. It drove fine during all that. Anyhow, shortly thereafter, it started to seem like it was kind of jerking at lower speeds, had a rough idle, almost where it might die. I replaced the front 3 spark plugs, as the back 3 require pulling intake manifold, was not ready for all that. Also changed 2 of the 4 O2 sensors I could locate. Mass air flow sensor error code. After installing 2 new MAF sensors, same performance and error. Anyhow, shortly thereafter, it started to lunge, with the RPM spiking. I replaced the 3 front spark plugs and 2 of the O2 sensors. That did not resolve the issue. It felt like it was starved for gas. Then my wife got stranded one night, it was in limp mode, and we had to have it towed to our house. Poking around in the engine bay, I found the large accordion hose from MAF to the throttle body had a major hole in it. I got a new hose, and the hesitation and rough idle went away. That resolved some of the lunging but did not resolve the RPM spiking. A new issue arose of driving smoothly to around 40 mph but then the RPMs increasing but the mph not increasing. Then came Code P0776 pressure control solenoid B. I replaced the transmission valve body with all the solenoids, as well as new NS-3 transmission fluid. My wife drove it to the end of our long driveway, and it threw a code there, which showed low transmission fluid level. We then checked the level with the silver drain plug, engine warm, seemed OK, added some until slightly more flow. Test drove again with me in vehicle this time. It acted like it was driving over ruble strips on the edge of the road, no power, engine seemed to match RPMs, we immediately turned around and brought it home. 3 error codes: P084C Transmission fluid pressure sensor/switch H circuit Low, P0847 transmission fluid pressure sensor/switch b circuit low, P0746 pressure control solenoid A performance/stuck off. I find the last one odd, since I just replaced the trans valve body, which contains the pressure control solenoid A. ANY help would be very much appreciated! I realize there is the possibility that the CVT transmission is shot, but I do not have $5000, let alone $1000 for a new trans.
  24. ShadowVampyre joined the community
  25. PhilB joined the community
  26. Personally I would direct compressed air around the area to see if I could clean it without removing components - you can get compressed air canisters to clean computers and keyboards. The possibly I would lightly apply some silicone spray around the area the noise is coming from but not too much, only a fine spray so as not to interfere with the SRS components.
  27. kenny joined the community
  28. Thank you for the explanation. What can I do about this. Is there something that needs replacing?
  29. Earlier
  30. Sometimes helps to breakdown carbon deposits but mainly using premium high octane/cetane fuels is best to help with cleaning up the combustion process.
  31. Hi...welcome to the Club Just do the bits that you can arrange to sort over time (wiper blades, tyres, etc) and just keep on top of servicing and any other issues that may crop up. Feel free to ask questions whenever you need advice
  32. Alan kho joined the community
  33. I bought my first Nissan, a K12 Micra, a couple of weeks back. It's not in the best shape, but I'm working to fix what I can. I will be asking questions when I get stuck, but much of what I am doing is pretty routine at the minute, well mostly.
  34. Okey! I’ll try and see if it helps. Maybe with some cleaning additive in the fuel?
  35. Its never too late to 'break it in' by slowly and gradually increasing the revs over time to get it used to revving higher - easiest way I've found is drive it the same as normal but just use a lower gear for longer periods....just do it gradually and run on premium fuels
  36. Thank you for your long reply :-) Okey, I hear you! I have been driven diesels for 35 years and a happy DIY mechanic, not afraid of projects. My daily driver is a Subaru XV 2012 diesel. Seldom rev it above 3000 rpm, and no problem with smoke or performance. But I do some full pulls now and then, so that might support your theory. Also have an Oldmobile 1982 350 v8 diesel, but that one never get a full pull, and does not smoke.. Some more history on the Nissan. It´s the wifes dailydriver, so it has not been driven hard. Normally cruises down the highway at 70 miles/h. When we bought the car it had about 21000 miles on it and was 3 years old. Does not touch the oil at all. I rarly fill in oil in between the services. Smoke from both oilfillercap and dipstick. I´m absolutley certain that this hasen´t been like this for mstart of ownership.. If your theory is correct, would you say that it´s to late to try an Italian service? Or let me put it like this, would you do it? I think I can organice a compression test, but the leakdown test will take some work as I don´t have the correct tools for the job. What bothers me is that the car has good performace and runs just fine... I appreciate your time! All the best
  37. I would normally agree with you regarding the engine being run in but if a previous owner just took it to the shops once a week or crawled through traffic in urban areas the engine would not necessarily be run in correctly (many diesel engines with high mileage can be stripped down and still find the honing marks scored into the bores....suggesting that the engine has not been run in correctly). I have torn down engines with just 21k miles and found the bores to be completely worn but equally I have found engines with over 100k miles to still be as fresh as the day it was built. It all depends on how it has been driven. Another example is a BMW R1200GS motorbike I had for many years. When I bought it, it was consuming quite a lot of engine oil, I changed the grade but it didn't like it (just yet). The bike had only covered 24k miles but it was sluggish and didn't respond as it should. I rode the bike hard (as it should be ridden) with high revs in each gear and eventually it was a completely different bike. No longer did it consume oil but I could happily change the oil grade accordingly. The long and short of it is that it was not run in correctly and I managed to change that by riding it hard for a period of time. Most diesel engines are not revved hard enough to burn off carbon (which could be gumming up the rings into the piston and not sealing in the cylinder efficiently, blocked EGR, blocked DPF, etc. All they usually need is an 'Italian Tune-up' to keep it all clean. Moral of this lengthy reply is - if it is consuming oil between services then I would consider that my theory is correct. Also try a cylinder leak-down test which will show exactly which cylinder or valves have pressure leaking past them. Very easy test with visible and audible results
  38. >Thank your for you´re input Trevor! As the car don´t produce any blue smoke from the exhaust, has good power and starts easy, I´m having hard to belive that the compression is poor. But you never know.. And as the milage isn´t high. But still I would say that it´s brooken in at 86000 miles. I have tried a additive that should give less friction (can´t remember the name), bu no additive for less smoke. I have one thing to try and that is if engine smokes from both dipstick and filler cap. I have understod that I can draw conclutions on the result of that test. Not sure what except that it´s worse if it smokes from both.
  39. I use a smart screen with Android Auto. Then connect my phone via BlueTooth and use Waze map. Less expensive and live updates of accidents, traffic jams etc.
  40. Hi All We can confirm our seasonal opening hours will be as follows: Up until the 19thDecember: Normal hours. Saturday 20th December: Closed Sunday 21st December: Closed Monday 22nd December: 9.00am – 3.00pm Tuesday 23rd December: 9.00am – 3.00pm Christmas Eve: 9.00am – 3.00pm Christmas Day: Closed Boxing Day: Closed Saturday 27th December: Closed Sunday 28th December: Closed Monday 29th December: 9.00am – 3.00pm Tuesday 30th December: 9.00am – 3.00pm New Years Eve: 9.00am – 3.00pm New Years Day: Closed Friday 2nd January: 9.00am – 3.00pm Saturday 3rd January: Normal Hours Resume. Regards, Dan
  41. I can only really find springs which will drop the height but not sure about other suspension components to complement the springs (dampers, links, etc) https://www.lkperformance.co.uk/car-parts/suspension/lowering-springs/nissan/pathfinder
