  2. Last week
  3. I would definitely advise to return the car to the garage who fitted the clutch for them to diagnose the issue - could be an adjustment required or a faulty part, etc?
  4. Just had a new clutch fitted to my 10 plate Pixo, all was good for about a week, now its quite hard and grinder when selecting a gear, mainly when down shifting and sometimes when shifting up. Suggestions would be greatly appreciated. Thanks guys
  5. Earlier
  6. Hi - welcome to the Club Fine looking Juke, not so sure I would manage to keep that paintwork clean all the time 🙂 Good to have you onboard!
  7. Make sure all sensors on the grill and windscreen areas are clean as dirt obscuring the sensors can result in this occuring
  8. Hi Lewis - welcome to the club Looks like a good spec Navara Major thing to have checked is the chassis for corrosion or cracks and believe the dealers have a recall and modified brackets to weld in (if it hasn't already been done)
  9. Hi Trevor - welcome to the club good to have you onboard and enjoy your Qashqai 🙂
  10. Hi All, My name is Trevor (TDS) and I have just joined club. have just purchased a Nissan Qashqai e-power from Vertu motors in Stockton. I was previously at Toyota C-HR owner. I am looking forward to driving such a great looking car.
  11. Hi all newbie here based in Northamptonshire recently brought a 2010 NAVARA 146 k on it been meticulously looked after by previous lady owner for 8 years dog walker I was told just wanted to say hello any input on issues or what I can do would be great
  12. Hi guys n gals Has anyone attempted to retro fit roof rails to a 2022 model ?
  13. I'm having trouble finding the front turn signal (original two-phase) on the left side of the Nissan Pathfinder 2002, does anyone know where to buy one?
  14. I have a 2019 xtrail t32 2019 tekna and looking to put in a viofo dashcam with parking mod and hardwire it in does any one what fuse to plug in for permanent power when car is park and fuse when car is running
  15. I'll be driving in rain on the Interstate and all of a sudden, the cruise control shuts down and the vehicle dramatically slows down. Dash says "Frontal collision" isn't working? WTH causes this?
  16. I had the 1 litre engine in my last Juke. Its turbocharged so there is no loss of power. I now have a 1.6 Hybrid which is more cost effective especially around urban areas.
  17. Hello all, meet Jimi. 1.2 Tekna, just past 37000 miles, owned for 2 weeks. My first Juke, loving it.
  18. I have a 2019 xtrail t32 2019 tekna and looking to put in a viofo dashcam with parking mod and hardwire it in does any one what fuse to plug in for permanent power when car is park and fuse when car is running
  19. I've been re-bushing the suspension on my Sunny Coupe and dicovered how rusty the brake splash shields are but I cannot find replacments. Do you know of someone who might have them?
  20. I would say it is more likely to be a gummed up turbo vanes fault which can be rectified by cleaning the turbo with a specialist cleaning solution (link below) https://www.ebay.co.uk/itm/292493130747?_skw=turbo+cleaner&itmmeta=01JTSXMZ9VE9ZW9F2H1DCM6423&hash=item4419f2fbfb%3Ag%3Ab9sAAOSwYutasp0A&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1fpV%2F8bmO6dppPkpUyUyyrTVatA%2BtxVHfyIQW%2BFrQfBfOZwB9GXDgirF%2FZx1wYQ5QWHnndTFW8dxHQnQwE2DJPM593%2FytgJBS5MLBDp8GWH%2FZutClKfIZWQSfoKddANZ7zaeBnZAo6VVmNaP6AcQjlZrAqIw0vsohppQpa1TRGcxd4sUcRwemDzU%2FgJBiFCwMC0j2OXXqnhoSWOhG9lxLcC0VLM4FFWpJ0NKLa%2FFsrMcFmbgwWZs209wAa7IvVnY8g%3D|tkp%3ABlBMUIL1073WZQ&keyword=turbo+cleaner&sacat=0&relatedSearch=true Once you have cleaned it and the vanes are free to move then a good italian tune-up should blast out any residue and carbon and should then run smoothly
  21. I would say that is an air conditioning system sensor - possibly system pressure sensor?
  22. Hi, I’ve replaced the horn in my 2005 Urbis and managed to accidentally break the wire next to it that goes into the radiator. Can anyone kindly confirm what it is and what it does so I can get a new part?
  23. okay, best bet really.....let us know how you get on with it
  24. Hi .... and welcome to the Club Great to have you onboard and feel free to post and answer any questions you feel able to answer. The Juke is a great car, my wife has one and just keeps going with minimal repairs (if any) but always maintained to keep it reliable.
  25. Hi guys hope your all well, I'm very thrilled to have found this group of nissan like minded people (how did i not know about this)🤣, I myself own a 1.5 2014 juke and absolutely love it, do you guys ever put on meets at all?
  26. Thank for this, but not confident enough to try myself, ill try and find a garage
  27. I would have a go yourself - switch ignition off and leave for half hour. (be careful as this is pyrotechnics and therefore explosive charge) Disconnect the electrical connectors under each seat, twist the wire one turn (so it has a slight bias on the connection when refitting) and reconnect. That may well solve the issue but because it is intermittent then it may not bring the light on straight away.
  28. Thanks, I would have thought this is something the nissan dealers would look at
