  2. Yesterday
  3. Hi everyone, I am Sid and I own a 1993 K reg 1.6 Sunny SR. Looking for a few bits and bobs and hopefully good advise. Thanks All.
  4. I own a 1.5dci Nissan pulsar 2015, and I want to change the CD player with a satnav unit. I was wondering if if anyone could help me find a wiring diagram for it as one of the original plugs doesn't fit into the new unit. I've had a look around and couldn't find one. Can anyone please help me?
  5. Hi enzso ....welcome to the club There is a reset procedure for the CVT transmission which may benefit you. CM (Transmission Control Module) reset by cycling the ignition and pressing the accelerator pedal, or disconnecting the battery. https://www.google.com/search?q=nissan+k13+automatic+gearbox+reset&rlz=1C5MACD_en&oq=nissan+k13+automatic+gearbox+reset&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigAdIBCTE0NzQ0ajBqN6gCALACAA&sourceid=chrome&ie=UTF-8 There are also videos on how to reset the transmission in this search link (above)
  6. Last week
  7. Just bought a K13 Micra auto with 80k on the odo. The gearbox is smooth and shifts well but I've noticed when it shifts from 3rd to 4th at around 40mph I get that familiar rumble when the revs are too low for the gear. The noise stays until I'm up around 45-50mph. It makes it tricky in 40mph zones as I'm having to use the overdrive switch to shift the car back to 3rd. Any tips?
  8. Does anyone know where to find rear right door glass for 1984 n11 4door cherry? Help please
  9. OK, I've managed to sort it now.
  10. It's on my trailer. I want to get another as a spare wheel. Tyre size is 165 R13C. What car does it come off?
  11. Earlier
  12. I have another question, that I hope will get a reply. On the speed dial, showing in the middle of the two main dials it shows KPH, while on the move.🤨 How can I change it to MPH, please? I can't seem to find it in "setting" Doh!!! Thank you in advance.
  13. In September 2024 I bought a brand-new Qashqai e-power when the weather went below 5° the car would not start the dashboard would not come on after many times trying to start it would eventually start one morning it would not start and my foot slipped off the break onto the accelerator and I could hear the engine come on but the dashboard remain off after going through five diagnostic checks and the dealer saying that there’s nothing wrong with the car eventually they decided after seven months to change the instrument panel on the dashboard now we have to wait till September October when the weather gets cold to see whether it worked or not I’m sure that i’m the only one that is experiencing is happening too
  14. Many thanks for this. Really helpful reply. Greg
  15. try Samco hoses - they are silicon and can be made to length and shape https://samcosport.com/car/
  16. Hi, I own a 2012 Micra which I love. I'm struggling to find a radiator hose for it 215033HD1B. I don't want to scrap it just for a hose - can anyine help?
  17. As long as the rolling diameter (overall diameter of the wheels / tyres) is the same all round then it shouldn't flag an ABS issue. You are able to have matched wheels on each axle and again they would need to be the same diameter as the others but do not need to be the same width
  18. I’m looking for a radiator for our scargo, damaged is ok providing the bottom tank is ok many thanks
  19. Hi all, I am the third owner of my 1994 Nissan Altima. I'm looking to get some help and advice on repairs that it needs. Can somebody point me in the right direction to which forum I would use I don't really see a Nissan Altima forum. Alternatively I could just say what's wrong with it here. I need to swap out the knock sensor and I'm not really sure how to get to it. If anybody knows the procedure I would be grateful. The knock sensor is behind the engine below the intake manifold.
  20. Hi there I have two Nissan Micra’s. One registered in 2017 has alloy wheels with tires 185/55 R16. The other car, registered in 2006 has steel wheels with tires 175/65 R15 T. My question is, can I fit all four steel wheels onto the later car or can I put two steel wheels on the same axle of the later car? Any advice would be much appreciated. Greg
  21. Hi all, I’m trying to replace the alternator on my 2017 Nissan Micra K14 Visia 1.0L (71PS – HR10DE engine), but I’ve hit a wall trying to get the belt off. I’ve located the tensioner pulley (the black one just above the alternator), but the centre is smooth — no bolt head or nut — and I can’t for the life of me find where to apply a tool to release the belt tension. I am no mechanic either .... wheels and fluids is usually my limit! I’ve checked above, behind, and around the tensioner pulley but can’t see a square hole or hex boss to rotate the tensioner arm. The engine bay is tight, and I’m not sure if I’m missing something obvious or if access is just that hidden. I’ve tried to follow online guides and videos, but most are for different engines or older models (K12/K13). Photos attached if that helps (can add more if needed). Any help — diagrams, tips, tooling advice — would be massively appreciated before I lose the will to live or call a mechanic 😅 Thanks in advance!
  22. Hi there, I have a 2022 Nissan Qashqai J12 Tekna (36 CAM, etc.), and my current display screen looks like this: [img]https://i.ibb.co/ZR3WXYr2/Screenshot-2025-06-19-at-11-48-41-Used-2022-BLUE-Nissan-Qashqai-1-3-Di-G-T-MH-158-Tekna-5dr-Xtronic.png[/img] I’m looking to upgrade it to this screen: [img]https://i.ibb.co/xZpfPGP/Screenshot-2025-06-19-at-11-48-30-Used-2022-GREY-Nissan-Qashqai-1-3-Di-G-T-MH-158-Tekna-5dr-Xtronic.png[/img] Can you confirm the following: Is this a direct plug-and-play swap? Will all existing cameras and sensors still function correctly? Is a PIN code or any additional programming required? Thanks in advance for your help! Best regards,
  23. thanks admin. I'll take some pics, and post later. Any views on the 1.2 engines?
  24. Welcome to the Club Bob
  25. Welcome to the Club
  26. Does anyone use this forum? was going to add............ I had to have the Thermostat & plastic casing replaced, costing £445. That's pretty much why I asked the question 😉
  27. Hi, New to the forum, as I just purchased the above Qashqai (Blue) Please don't tell me I've purchased a lame duck? I like it so far, but others don't, so I've read elsewhere. it's taking me a while to understand all the steering wheel gumph etc. I'd like to know what others' opinions are here please?
  28. You should be able to find a set of halogen headlamps which are completely different to Xenon type Try Partsfinder or eBay to see if there is a pair for sale
  29. Hi folks. Im new to this, but im trying desperately to sell my 1989 silver nissan sunny. She's in good condition and has been garaged for 10 yrs. Iv had it from New, so one owner. She needs a service,MOT and taxed⁷. She's nearly 40yrs old and the milage is 130,000... shes an old lady with plenty of life her still. Thanks for readying my story.
