  2. Hi @SteveG Do you have 2wd on this or is it constant 4wd> Also i presume this is an automatic?
  3. Hi Adrian Have you tried looking for universal strips on ebay? if you find the right size I believe the join needs to be at the bottom
  4. HI Kelvin Have you changed the battery on the keyfob recently?
  5. this really sounds like an earthing issue or something has been chewing on wiring. Do you live in the countryside?
  6. welcome to the club! Hope you enjoy the new Juke :) Any questions, drop by and ask :)
  7. Today
  8. Looking forward to being a owner of a 2023 juke
  9. Strongman Dad joined the community
  10. Yesterday
  11. JimboSlice1705 joined the community
  12. Hello. I have a 2015 Juke Tekna (diesel with auto start/stop) with some electrical issues that are ..odd. All have been happening for well over a year and nobody can find the problem. The issues are; Radio unit loses all power then comes back on. It happens randomly and can be off anywhere from 5 seconds to 30 minutes. It often comes back on if I slow down and put the clutch in to change gear. The auto start stop light randomly flashes green when driving. The battery light blinks red on occasion when stationary / idling at lights. Headlights are noticeably dimming/brightening like a pulse when driving, especially when the radio unit is messing around. Key battery low warning light comes on often even if it has a new battery in. The car drives fine. It's had a software update from Nissan, they couldn't find any other issues. My local garage has looked at it multiple times and cannot locate a problem. It's had 2 new batteries in the last 2 years and the alternator has been checked when I requested it, it was fine. I'm out of ideas, my local garage is out of ideas, it's more annoying than anything especially the radio/nav being unusable a lot of the time. Anyone experienced any of this before and found a solution?
  13. williams_k joined the community
  14. Recently, the key fob for my 2014 Nissan Note has been able to unlock all the doors except the boot. Please advise on what the possible fault might be.
  15. Need weather door strips.would anyone know where I can get some from please. It would be a shame to scrap the car, also for future knowledge is it still possible to get a window screen. Please can you help me.
  16. Last week
  17. RobertW joined the community
  18. I have a 2013 J10 4WD . I have jacked the front wheels up, transmission in neutral but the wheels are not spinning freely, as they should. I can feel the transmission moving as I rotate the wheel. Is there a known issue or does anyone have any idea what could be the issue? Thanks
  19. SteveG joined the community
  20. marktrans joined the community
  21. 2005 Nissan Primera Engine fault appears saying PO171 Fuel System Lean fault and fuel economy has skyrocketed. 2 mechanics have said can be many things and don't want to really get involved. Anyone else had similar issues? Also key fob not working even after changing battery. Has been playing up for a while where I need to make a clicking noise when key is taken out of ignition but now is not working. Thanks in advance
  22. Hey all, new to this forum. My partner's pulsar has done 112,000 klms and the CVT is broken and rattling. We dont have the $6,000 to fix it. What other options do I have? eg 2nd hand tranny, reconditioned tranny, repair. Any other advice? Rob.
  23. Robbennettcolyton joined the community
  24. T.S joined the community
  25. Craig v joined the community
  26. Earlier
  27. Turns out the second device is part of the security system, some kind of sensor.
  28. Ciao Riki Enjoy the Xtrail my friend. Happy new year!
  29. hi The 2nd one may be ETC toll collector. Does it have a slot for a card?
  30. Hi All 2015 Nissan Serena: Any ideas on what these two are for ?
  31. Hi @Riki .... welcome to the club Enjoy your X-Trail when you get it
  32. Trevor started following Hello From italy
  33. Good day to all you Jukie owners. My Nissan Juke doesn’t seem very fuel efficient for a small car. I mainly do short trips and I’m only getting low 30s mpg. It’s a 1.2 DIG-T petrol. I was expecting better but maybe that’s just unrealistic. Is this normal for the Nissan Juke or should I be checking things like tyre pressures, air filter or spark plugs? Curious what other owners actually get day to day. Cheers Guys
  34. Riki started following Nissan X-Trail Forum
  35. Hello to everyone! I'm buying an x Trail e-power 4x4!
  36. Hi - I was checking the timing on my Pulsar 1.2 DIG-T engine and the chain has slipped while turning the crankshaft. Is there a way to fix this without removing the head?
  37. That sounds like one of the wheel sensors has gone faulty - a scan of the fault codes in the ABS system will more than likely show a code for a wheel sensor
  38. Trevor started following Navara 2021
  39. My navara has has 2 amber warning lights come on when driving, crash detecion and traction control. Just wondering if any of yous know what this could be Many thanks
  40. I am guessing it is part of the process for charging the battery but I would double check it with the dealer or Google search the symptoms and see what you can find
