Strange electrical issues
New owner of a 2023 juke
Looking forward to being a owner of a 2023 juke
Strongman Dad joined the community
JimboSlice1705 joined the community
Hello. I have a 2015 Juke Tekna (diesel with auto start/stop) with some electrical issues that are ..odd. All have been happening for well over a year and nobody can find the problem. The issues are; Radio unit loses all power then comes back on. It happens randomly and can be off anywhere from 5 seconds to 30 minutes. It often comes back on if I slow down and put the clutch in to change gear. The auto start stop light randomly flashes green when driving. The battery light blinks red on occasion when stationary / idling at lights. Headlights are noticeably dimming/brightening like a pulse when driving, especially when the radio unit is messing around. Key battery low warning light comes on often even if it has a new battery in. The car drives fine. It's had a software update from Nissan, they couldn't find any other issues. My local garage has looked at it multiple times and cannot locate a problem. It's had 2 new batteries in the last 2 years and the alternator has been checked when I requested it, it was fine. I'm out of ideas, my local garage is out of ideas, it's more annoying than anything especially the radio/nav being unusable a lot of the time. Anyone experienced any of this before and found a solution?
williams_k joined the community
Kelvin started following Issue with 2014 Nissan Note Boot Lock
RobertW joined the community
SteveG joined the community
Navara 2021
T.S started following 2005 Primera PO171 Fuel System Lean fault
2005 Nissan Primera Engine fault appears saying PO171 Fuel System Lean fault and fuel economy has skyrocketed. 2 mechanics have said can be many things and don't want to really get involved. Anyone else had similar issues? Also key fob not working even after changing battery. Has been playing up for a while where I need to make a clicking noise when key is taken out of ignition but now is not working. Thanks in advanceRobbennettcolyton started following nissan pulsar 2013 C 12 CVT issues - Sydney Australia- nissan pulsar 2013 C 12 CVT issues - Sydney Australia
Hey all, new to this forum. My partner's pulsar has done 112,000 klms and the CVT is broken and rattling. We dont have the $6,000 to fix it. What other options do I have? eg 2nd hand tranny, reconditioned tranny, repair. Any other advice? Rob.Robbennettcolyton joined the communityT.S joined the communityCraig v joined the community- Earlier
- Nissan Serena
Turns out the second device is part of the security system, some kind of sensor.- Nissan Serena
- Hello From italy
Ciao Riki Enjoy the Xtrail my friend. Happy new year!- Nissan Serena
hi The 2nd one may be ETC toll collector. Does it have a slot for a card?- Nissan Serena
- Hello From italy
Hi @Riki .... welcome to the club Enjoy your X-Trail when you get itTrevor started following Hello From italy- Poor fuel economy on Nissan Juke around town
Good day to all you Jukie owners. My Nissan Juke doesn’t seem very fuel efficient for a small car. I mainly do short trips and I’m only getting low 30s mpg. It’s a 1.2 DIG-T petrol. I was expecting better but maybe that’s just unrealistic. Is this normal for the Nissan Juke or should I be checking things like tyre pressures, air filter or spark plugs? Curious what other owners actually get day to day. Cheers GuysRiki started following Nissan X-Trail Forum- Hello From italy
Hello to everyone! I'm buying an x Trail e-power 4x4!- Timing chain slipped
Hi - I was checking the timing on my Pulsar 1.2 DIG-T engine and the chain has slipped while turning the crankshaft. Is there a way to fix this without removing the head?- Navara 2021
That sounds like one of the wheel sensors has gone faulty - a scan of the fault codes in the ABS system will more than likely show a code for a wheel sensorTrevor started following Navara 2021- Navara 2021
My navara has has 2 amber warning lights come on when driving, crash detecion and traction control. Just wondering if any of yous know what this could be Many thanks- Strange engine noise on Nissan Qashqai e-Power when stationary
