Wargra joined the community
sid joined the community
Lisa Morris joined the community
enzso joined the community
Nic joined the community
Adrianco22 joined the community
Maroje joined the community
crypticsilenc3 joined the community
Bojana Kalendarska joined the community
In September 2024 I bought a brand-new Qashqai e-power when the weather went below 5° the car would not start the dashboard would not come on after many times trying to start it would eventually start one morning it would not start and my foot slipped off the break onto the accelerator and I could hear the engine come on but the dashboard remain off after going through five diagnostic checks and the dealer saying that there’s nothing wrong with the car eventually they decided after seven months to change the instrument panel on the dashboard now we have to wait till September October when the weather gets cold to see whether it worked or not I’m sure that i’m the only one that is experiencing is happening too - Earlier
Welcome to the Club Bob
Welcome to the Club
Xenon Headlights
