  2. V8Pathfinder joined the community
  3. Redeceptor joined the community
  4. Yesterday
  5. YES! Night ferry ....
  6. Last week
  7. Hello everyone , I'm Steve, a new member & would appreciate any help with my 1.6 dci 2012 qashqai. my obd reader indicated a faulty circuit A , I replaced all glow plugs , but problem persists , long cranking especially in cold weather , to start the car . I gather the relay or fuse may be responsible , but unsure of there location & accessibility . Any help appreciated ! Thanks
  8. Esteban joined the community
  9. this is for a campervan but has some good points
  10. will you be driving at night?
  11. Thanks for replying! Um, yes, I got square eyes looking on Youtube and found nothing. Hence my message on here. 🙅‍♀️
  12. Hi Rose Are you likely to be driving at night? If yes then they should go on the nearside (passenger side) but yes your right, its not easy. I drive without them as I have flat LED but if you want to be legal then stick them on. Have you tried Youtube?
  13. Hi folks! I'm driving to France so need to put on some beam deflectors on my Qashqai 2021. I've bought Eurolites, and having read the instructions I understand that I need to apply them using picture 146 but to be honest, I really don't understand where to stick them! (Also they're not the same position on both lights 🙄) . I've been looking, but can't find, any photos of beam deflectors on Qashqais so I can copy. Can anyone help?? Am I the only one who finds this difficult? Any advice gratefully received. TY
  14. I need rear brake adjusters for my 85 Stanza hatchback, its a T-11
  15. Richard G joined the community
  16. Snarf_Dude joined the community
  17. Hi
    Welcome to the club @Rhino
  18. Hi
  19. Hi
  20. Rhino joined the community
  21. Calum1705 joined the community
  22. Murano joined the community
  23. Hi Trevor, thanks for your suggestion. I'm not all that savvy with this internet thing. I'm with Orange in France. I presume when the Micra is asking for my password they mean the long list of letter and numbers that came with my love of. I have had to use that to get the internet on my tablet and laptop . Is there any other password?
  24. Hi...welcome to the Club sounds simplistic - but can't you change your internet password to a shorter one so that the characters fit?
  25. What is the actual issue with the car? Also, is it engine speed or vehicle speed sensor you are looking at?
  26. peter Garratt joined the community
  27. I've never used a forum so bare with me please. I have a 2006 6cyl Pathfinder 4×4. I need to find out exactly where the input shaft speed sensor is located!! Took the driver wheel off and can't even see where it goes!! Help please . I know on outside of tranny! HELP
  28. Hawthorne Lorna joined the community
  29. ☹️internet connection Recently bought a 2022 Micra Business K14. For some reason it won't accept the last digit of my Internet password so I cannot get Nissan updates. Why
  30. I know... so nothing. But, Thanks.
  31. I use iCarSoft scanner so not sure about the Topdon but most scan tools are of the same standard and will read and delete fault codes. Beyond that, scanners such as the iCarSoft can also code injectors, reset base values and quite a bit more
  32. The only thing I can think of is when you lock/unlock and hold the button down for a period of time then the windows will lower or raise? Otherwise, not sure what could be causing it to drop the windows
  33. Here is some more information on the fault and a video showing how to fix it (Google AI search of fault code P0002) P0002 is an OBD-II diagnostic trouble code for a fuel volume regulator control circuit range/performance issue, indicating the engine control unit (ECU) has detected a problem with the fuel volume regulator. This can be caused by a faulty fuel pump, regulator, or a problem with wiring, connectors, or a clogged fuel filter. Symptoms often include a illuminated check engine light, poor engine performance, and the vehicle entering "limp mode".
  34. Earlier
  35. In diagnostic, "Consult" for Nissan? I tryed... and nothing, Dealer Nissan and nothing. Car is normally go, but maybe I listening turbo pressure up\down. Blick red error of motor and car is normally go, but pressure is normal at now. I Stop the car and again start the motor, and error is resset some kilometrs. Insane car... realy
  36. Is there a known issue with 2010 Muranos that causes the front windows to lower without input?
  37. I am considering having a Topdon Carpal as my OBD diagnostic tool. Has anyone on this forum had any experience of this model?
  38. Can you turn of off the electric mirror fold , so is it possible to move them in/out manually ? So I can get the car in / out of the garage
