My led headlight has a malfunction, I've only had my car for eight months and I've got two years warranty on it should this be covered for repair
russty joined the community
Navara 2021
- Timing chain slipped
Trevor started following New owner of a 2023 juke , Timing chain slipped , Issue with 2014 Nissan Note Boot Lock and 4 others
Nissan Serena
K14_CVT joined the community
Strange electrical issues
Looking forward to being a owner of a 2023 juke
Strongman Dad joined the community
JimboSlice1705 joined the community
Hello. I have a 2015 Juke Tekna (diesel with auto start/stop) with some electrical issues that are ..odd. All have been happening for well over a year and nobody can find the problem. The issues are; Radio unit loses all power then comes back on. It happens randomly and can be off anywhere from 5 seconds to 30 minutes. It often comes back on if I slow down and put the clutch in to change gear. The auto start stop light randomly flashes green when driving. The battery light blinks red on occasion when stationary / idling at lights. Headlights are noticeably dimming/brightening like a pulse when driving, especially when the radio unit is messing around. Key battery low warning light comes on often even if it has a new battery in. The car drives fine. It's had a software update from Nissan, they couldn't find any other issues. My local garage has looked at it multiple times and cannot locate a problem. It's had 2 new batteries in the last 2 years and the alternator has been checked when I requested it, it was fine. I'm out of ideas, my local garage is out of ideas, it's more annoying than anything especially the radio/nav being unusable a lot of the time. Anyone experienced any of this before and found a solution?
williams_k joined the community
Kelvin started following Issue with 2014 Nissan Note Boot Lock
RobertW joined the community
SteveG joined the community
Navara 2021
Hey all, new to this forum. My partner's pulsar has done 112,000 klms and the CVT is broken and rattling. We dont have the $6,000 to fix it. What other options do I have? eg 2nd hand tranny, reconditioned tranny, repair. Any other advice? Rob. - 2005 Primera PO171 Fuel System Lean fault
