  2. It's on the chassis rail right hand side (outer) under the drivers door. Literally bend down and you should see it straight under the sill. Found this on a Navara site, also it should be on the body below the windscreen area but if all else fails it will be printed on your vehicle logbook
  3. Well the induction hose you replaced was definitely the culprit and as that was perished I would also look for any other hoses that may have holes or splits through perishing over the years. An increase in revs is usually a vacuum leak through a perished or split hose. As for the transmission - it is hard to tell what the issue is but I would advise to get it to a transmission specialist for them to set it up correctly - may need calibration through specialist equipment
  4. Yesterday
  5. Hi Guys Looking for VIN number Location, I have the one on the windscreen and the one on the inside of the door, i have looked on the Chassis under neath as you open the driver's door,and its not there, is there any other place it can be? Your Help would be appreciated Thanks.
  6. 9006 joined the community
  7. I have a 2014 Nissan Pathfinder SL 3.5L V6. When my wife bought this in September 2025, it seemed fine at the time, no transmission or engine issues. She drove it home for 2.5 hours, then around town for a few days. I was out of town at this time, and she drove to pick me up, 3 hours each way. It drove fine during all that. Anyhow, shortly thereafter, it started to seem like it was kind of jerking at lower speeds, had a rough idle, almost where it might die. I replaced the front 3 spark plugs, as the back 3 require pulling intake manifold, was not ready for all that. Also changed 2 of the 4 O2 sensors I could locate. Mass air flow sensor error code. After installing 2 new MAF sensors, same performance and error. Anyhow, shortly thereafter, it started to lunge, with the RPM spiking. I replaced the 3 front spark plugs and 2 of the O2 sensors. That did not resolve the issue. It felt like it was starved for gas. Then my wife got stranded one night, it was in limp mode, and we had to have it towed to our house. Poking around in the engine bay, I found the large accordion hose from MAF to the throttle body had a major hole in it. I got a new hose, and the hesitation and rough idle went away. That resolved some of the lunging but did not resolve the RPM spiking. A new issue arose of driving smoothly to around 40 mph but then the RPMs increasing but the mph not increasing. Then came Code P0776 pressure control solenoid B. I replaced the transmission valve body with all the solenoids, as well as new NS-3 transmission fluid. My wife drove it to the end of our long driveway, and it threw a code there, which showed low transmission fluid level. We then checked the level with the silver drain plug, engine warm, seemed OK, added some until slightly more flow. Test drove again with me in vehicle this time. It acted like it was driving over ruble strips on the edge of the road, no power, engine seemed to match RPMs, we immediately turned around and brought it home. 3 error codes: P084C Transmission fluid pressure sensor/switch H circuit Low, P0847 transmission fluid pressure sensor/switch b circuit low, P0746 pressure control solenoid A performance/stuck off. I find the last one odd, since I just replaced the trans valve body, which contains the pressure control solenoid A. ANY help would be very much appreciated! I realize there is the possibility that the CVT transmission is shot, but I do not have $5000, let alone $1000 for a new trans.
  8. ShadowVampyre joined the community
  9. Last week
  10. PhilB joined the community
  11. Personally I would direct compressed air around the area to see if I could clean it without removing components - you can get compressed air canisters to clean computers and keyboards. The possibly I would lightly apply some silicone spray around the area the noise is coming from but not too much, only a fine spray so as not to interfere with the SRS components.
  12. kenny joined the community
  13. Thank you for the explanation. What can I do about this. Is there something that needs replacing?
  14. Sometimes helps to breakdown carbon deposits but mainly using premium high octane/cetane fuels is best to help with cleaning up the combustion process.
  15. Hi...welcome to the Club Just do the bits that you can arrange to sort over time (wiper blades, tyres, etc) and just keep on top of servicing and any other issues that may crop up. Feel free to ask questions whenever you need advice
  16. Alan kho joined the community
  17. I bought my first Nissan, a K12 Micra, a couple of weeks back. It's not in the best shape, but I'm working to fix what I can. I will be asking questions when I get stuck, but much of what I am doing is pretty routine at the minute, well mostly.
  18. Suzanne joined the community
  19. frank5079 joined the community
  20. Okey! I’ll try and see if it helps. Maybe with some cleaning additive in the fuel?
  21. Its never too late to 'break it in' by slowly and gradually increasing the revs over time to get it used to revving higher - easiest way I've found is drive it the same as normal but just use a lower gear for longer periods....just do it gradually and run on premium fuels
  22. Thank you for your long reply :-) Okey, I hear you! I have been driven diesels for 35 years and a happy DIY mechanic, not afraid of projects. My daily driver is a Subaru XV 2012 diesel. Seldom rev it above 3000 rpm, and no problem with smoke or performance. But I do some full pulls now and then, so that might support your theory. Also have an Oldmobile 1982 350 v8 diesel, but that one never get a full pull, and does not smoke.. Some more history on the Nissan. It´s the wifes dailydriver, so it has not been driven hard. Normally cruises down the highway at 70 miles/h. When we bought the car it had about 21000 miles on it and was 3 years old. Does not touch the oil at all. I rarly fill in oil in between the services. Smoke from both oilfillercap and dipstick. I´m absolutley certain that this hasen´t been like this for mstart of ownership.. If your theory is correct, would you say that it´s to late to try an Italian service? Or let me put it like this, would you do it? I think I can organice a compression test, but the leakdown test will take some work as I don´t have the correct tools for the job. What bothers me is that the car has good performace and runs just fine... I appreciate your time! All the best
  23. Earlier
  24. I would normally agree with you regarding the engine being run in but if a previous owner just took it to the shops once a week or crawled through traffic in urban areas the engine would not necessarily be run in correctly (many diesel engines with high mileage can be stripped down and still find the honing marks scored into the bores....suggesting that the engine has not been run in correctly). I have torn down engines with just 21k miles and found the bores to be completely worn but equally I have found engines with over 100k miles to still be as fresh as the day it was built. It all depends on how it has been driven. Another example is a BMW R1200GS motorbike I had for many years. When I bought it, it was consuming quite a lot of engine oil, I changed the grade but it didn't like it (just yet). The bike had only covered 24k miles but it was sluggish and didn't respond as it should. I rode the bike hard (as it should be ridden) with high revs in each gear and eventually it was a completely different bike. No longer did it consume oil but I could happily change the oil grade accordingly. The long and short of it is that it was not run in correctly and I managed to change that by riding it hard for a period of time. Most diesel engines are not revved hard enough to burn off carbon (which could be gumming up the rings into the piston and not sealing in the cylinder efficiently, blocked EGR, blocked DPF, etc. All they usually need is an 'Italian Tune-up' to keep it all clean. Moral of this lengthy reply is - if it is consuming oil between services then I would consider that my theory is correct. Also try a cylinder leak-down test which will show exactly which cylinder or valves have pressure leaking past them. Very easy test with visible and audible results
  25. >Thank your for you´re input Trevor! As the car don´t produce any blue smoke from the exhaust, has good power and starts easy, I´m having hard to belive that the compression is poor. But you never know.. And as the milage isn´t high. But still I would say that it´s brooken in at 86000 miles. I have tried a additive that should give less friction (can´t remember the name), bu no additive for less smoke. I have one thing to try and that is if engine smokes from both dipstick and filler cap. I have understod that I can draw conclutions on the result of that test. Not sure what except that it´s worse if it smokes from both.
  26. I use a smart screen with Android Auto. Then connect my phone via BlueTooth and use Waze map. Less expensive and live updates of accidents, traffic jams etc.
  27. Hi All We can confirm our seasonal opening hours will be as follows: Up until the 19thDecember: Normal hours. Saturday 20th December: Closed Sunday 21st December: Closed Monday 22nd December: 9.00am – 3.00pm Tuesday 23rd December: 9.00am – 3.00pm Christmas Eve: 9.00am – 3.00pm Christmas Day: Closed Boxing Day: Closed Saturday 27th December: Closed Sunday 28th December: Closed Monday 29th December: 9.00am – 3.00pm Tuesday 30th December: 9.00am – 3.00pm New Years Eve: 9.00am – 3.00pm New Years Day: Closed Friday 2nd January: 9.00am – 3.00pm Saturday 3rd January: Normal Hours Resume. Regards, Dan
  28. Jamallio joined the community
  29. I can only really find springs which will drop the height but not sure about other suspension components to complement the springs (dampers, links, etc) https://www.lkperformance.co.uk/car-parts/suspension/lowering-springs/nissan/pathfinder
  30. A couple of things come to mind - you could also try some additives to see if this improves things. If it is breathing heavy then usually bores/rings, etc but if you have tested compression (wet and dry) then this may not be an issue. Worth considering an additive such as StopSmoke or similar to see if any difference and also may change the engine oil for a heavier weight. Finally, if the car has been driven in a high gear and just cruised along for most of its life then it probably isn't run in yet....diesels (as you may know) need to be run hard to bed everything in and to maintain and low carbon emission level (gummed up rings, etc)
  31. This is quite normal as it dims everything for nighttime driving. If you have the infotainment screen fitted then this also dims as well
  32. hi i've got a nissan juke i put the lights on and the light round the heater goes dim is a fuse or something wrong please help it's a nissan juke 2013 plate
  33. There was I thinking a System Fault must be serious but after some delving into the reams of paper that make up the Leaf owners book, I find that it is nothing major after all. I think one of the radars giving blind spot protection must have failed because switching off all of these functions the warning has gone! I don't think I will bother to do anything about this as if there was one function I would consider completely uneccessary in a car it would be this. The electronics systems fitted in modern cars, to my mind , is ridiculous. I suppose it is all leading up to when the human driver is superfluous? I also wish Nissan would include a manual that is specific to the actual model to which is it issued it is very confusing to have a manual that has all the items fitted to all models and nothing to indicate what is not fitted to a particular car! I am considering purchasing one of those OBDs, the Topdon Carpal looks like a good contender but I could not find anything on their website to see if it can diagnose faults in a Nissan Leaf. Perhaps there is someone on this site that would know?
  34. Topaz joined the community
  35. GTE joined the community
  36. Doesn't your fuel flap lock when you lock the car? Mine certainly does. Maybe your just wanting extra security - if so ignore my post 👍
  37. usually when charging, whether on a charger or from an alternator it will usually sit in the 13v mark. Interesting to that the interior light causes that surge, battery maybe weak for some reason, although 4 years is not that old. But stuff happens. might be worth investing in a scan tool when the car comes out of warranty. As dealers charge so much money for such little work
  38. Thanks for your support, Steve. I tried to replicate your instructions but I could not get the response on my Leaf no matter what buttons I pressed! One thing I did notice was the 12v battery (it's always the 12v battery!) was only reading 12v and any load such as interior light dropped it to less than 12. I have now put the vehicle on charge and notice that this also charges the 12v battery, now reading over 13v. Hoping this might be the answer. But if not the car is in warranty so will take it back to the dealer for them to fix.
  39. please let us know the results and what it was.. may help other leaf owners Cheers
