Lamonta333 joined the community
Cheers Steve for that,has put my mind at ease a bit got the car booked in on Thursday for them to check it out let you know the outcome
BizChuck joined the community
My led headlight has a malfunction, I've only had my car for eight months and I've got two years warranty on it should this be covered for repair
russty joined the community
Navara 2021
- Timing chain slipped
Trevor started following New owner of a 2023 juke , Timing chain slipped , Issue with 2014 Nissan Note Boot Lock and 4 others
Nissan Serena
K14_CVT joined the community
Strange electrical issues
Looking forward to being a owner of a 2023 juke
Strongman Dad joined the community
JimboSlice1705 joined the community
Hello. I have a 2015 Juke Tekna (diesel with auto start/stop) with some electrical issues that are ..odd. All have been happening for well over a year and nobody can find the problem. The issues are; Radio unit loses all power then comes back on. It happens randomly and can be off anywhere from 5 seconds to 30 minutes. It often comes back on if I slow down and put the clutch in to change gear. The auto start stop light randomly flashes green when driving. The battery light blinks red on occasion when stationary / idling at lights. Headlights are noticeably dimming/brightening like a pulse when driving, especially when the radio unit is messing around. Key battery low warning light comes on often even if it has a new battery in. The car drives fine. It's had a software update from Nissan, they couldn't find any other issues. My local garage has looked at it multiple times and cannot locate a problem. It's had 2 new batteries in the last 2 years and the alternator has been checked when I requested it, it was fine. I'm out of ideas, my local garage is out of ideas, it's more annoying than anything especially the radio/nav being unusable a lot of the time. Anyone experienced any of this before and found a solution?
williams_k joined the community
Kelvin started following Issue with 2014 Nissan Note Boot Lock
RobertW joined the community
