Thurso xtrail started following Dashcam
foxleybob started following new qashqai
Hi all, just purchased a used Nissan Qashqai 1.2 dci tekna 5dr. I have yet to pick it up (tomorrow). Would anyone like to comment on this particular version please? (Good & bad :D)?
scooty joined the community
JohnM joined the community
Rs1984 joined the community
Zac joined the community
Thank you
