Nissan Serena
New owner of a 2023 juke
K14_CVT joined the community
Strange electrical issues
Looking forward to being a owner of a 2023 juke
Strongman Dad joined the community
JimboSlice1705 joined the community
Hello. I have a 2015 Juke Tekna (diesel with auto start/stop) with some electrical issues that are ..odd. All have been happening for well over a year and nobody can find the problem. The issues are; Radio unit loses all power then comes back on. It happens randomly and can be off anywhere from 5 seconds to 30 minutes. It often comes back on if I slow down and put the clutch in to change gear. The auto start stop light randomly flashes green when driving. The battery light blinks red on occasion when stationary / idling at lights. Headlights are noticeably dimming/brightening like a pulse when driving, especially when the radio unit is messing around. Key battery low warning light comes on often even if it has a new battery in. The car drives fine. It's had a software update from Nissan, they couldn't find any other issues. My local garage has looked at it multiple times and cannot locate a problem. It's had 2 new batteries in the last 2 years and the alternator has been checked when I requested it, it was fine. I'm out of ideas, my local garage is out of ideas, it's more annoying than anything especially the radio/nav being unusable a lot of the time. Anyone experienced any of this before and found a solution?
williams_k joined the community
Kelvin started following Issue with 2014 Nissan Note Boot Lock
RobertW joined the community
SteveG joined the community
Navara 2021
T.S started following 2005 Primera PO171 Fuel System Lean fault
2005 Nissan Primera Engine fault appears saying PO171 Fuel System Lean fault and fuel economy has skyrocketed. 2 mechanics have said can be many things and don't want to really get involved. Anyone else had similar issues? Also key fob not working even after changing battery. Has been playing up for a while where I need to make a clicking noise when key is taken out of ignition but now is not working. Thanks in advance- Earlier
Robbennettcolyton started following nissan pulsar 2013 C 12 CVT issues - Sydney Australia- nissan pulsar 2013 C 12 CVT issues - Sydney Australia
Hey all, new to this forum. My partner's pulsar has done 112,000 klms and the CVT is broken and rattling. We dont have the $6,000 to fix it. What other options do I have? eg 2nd hand tranny, reconditioned tranny, repair. Any other advice? Rob.Robbennettcolyton joined the communityTrevor started following New owner of a 2023 juke , 2005 Primera PO171 Fuel System Lean fault , nissan pulsar 2013 C 12 CVT issues - Sydney Australia and 1 other- Nissan Serena
Turns out the second device is part of the security system, some kind of sensor.- Nissan Serena
- Hello From italy
Ciao Riki Enjoy the Xtrail my friend. Happy new year!- Nissan Serena
hi The 2nd one may be ETC toll collector. Does it have a slot for a card?- Nissan Serena
