Electrical issues with the 2020 Kicks
Trevor started following Electrical issues with the 2020 Kicks
Sluggish Qashqai
Sluggish Qashqai
Yes its quite normal for the hoses to expand when pressurised from the turbo boost however, if they feel very soft and squidgy when you squeeze them they are probably in need of replacement as the rubber would be perished with age
Noisy Sunroof
Greetings and salutations!
2005 Bluebird Sylphy G10L shifter removal
Simonius joined the community
Sluggish Qashqai
Riles joined the community
Decent price for it
Cheers for this
Noisy Sunroof
Jeannie joined the community
Rstuner joined the community
Katman joined the community
Problem turning on radio
Trevor started following Problem turning on radio
problem with my CV Joint
Decent price for it
Decent price for it
my radio is knackered
Sluggish Qashqai
Sluggish Qashqai
Sluggish Qashqai
Sluggish Qashqai
Speed camera detection
Sluggish Qashqai
- Radio satnav
