  1. Last week
  2. It would seem, and I would wholeheartedly agree. Although, technically, you could leave all previous weights on a wheel for forever, and just keep balancing it with additional weights as necessary!??? 😂 Not the case here though. All the weights are fresh new. They put both push on weights and stick on weights. Push on weights went to the inside of each wheel. Stick on weights are to the outside behind the spokes on the aluminum mag wheels. And.. as stated.. opposite each other in three of the four, and about 2 hours on the clock location off opposite on the fourth. It’s very weird. I have personally balanced a lot of motorcycle wheels in my life.. and it’s always one weight.
  3. Thanks mate will do. Need to find a few bits and bobs but the car is mechanically sound.
  4. Thanks again. I’ve put in new batteries and tried the other fob for a while before. It is so random I am wondering if the door keyless buttons send a signal like the fob or they are hardwired. I’m thinking possibly the rf receiver is getting old and cranky like the rest of us….
  5. no that seems fine as long as the lights switch on and off I wonder if the drivers door lock is faulty as it should control the rest of the doors locking and unlocking The fob may be faulty but try a quality battery and also check any microswitches for the buttons that may have become detached from the circuit board
  6. Tried all the doors, they all put light on with a delay. Boot and tailgate both put light on and straight off. Is this the issue?
  7. Thanks Trevor I will test this tonight.
  8. It is necessary to remove all weights if out of balance before fitting new ones when replacing tyres If the amount of weights are too large then it is sometimes best to spin the tyre around on the rim to cancel out the imbalance
  9. I would check the door switch which signals the system that the door is opened or closed and can trigger the alarm if wrong signal given Open in each door including bonnet, load area and all others to see if the interior light comes on and goes out after a while
  10. Hi....welcome to the Club
  11. Hi....welcome to the forum Good to have you onboard
  12. oh very nice car ! Welcome to the forum and keep us updated on the progress
  13. I would start by checking the electrical connection into the motor and if it spins up when you turn everything on the there's the problem
  14. Earlier
  15. Any idea what it could be though?
  16. I would start by removing the glovebox to see how much access you gain, if not much then continue to remove more dashboard components
  17. After some help. My air blower is intermittent, some tomes it works sometimes it doesn't. Fuse has been checked, not sure if a new fan is required? Do you get to it by taking the glovebox out rather than the whole dashboard?
  21. Hi all new to the group just wanted go introduce myself. I’m Adam and I’m in North Yorkshire I have a 02 Nissan 350z that I was recently given by my dad as it’s been sat for 2yrs. it had a little work done before it got parked up but it still needs a bit of love. tell me what you think.
  22. Hi all, I have a 2013 D40 Tekna with a factory-fitted reversing camera which is sited under the handle to open the boot/cargo area. The handle has broken and I cannot find a replacement anywhere. All the ones I can find are standard, without a cutout for the camera, which won't fit - I have attached pictures to show the cutout. Has anyone ever had to replace their handle, and been able to find a suitable replacement?
  23. Hello all, I am new to here and hope you can help, my qashqai has developed this issue when starting in the morning, it struggles to start with a funny turning over sound and eventually when it starts there is alot of white smoke and it idles rough but once it is warm it runs perfectly but with still a bit of smoke, I have been looking around the net, I have seen leaking or faulty injector a clogged up PCV valve I did have the Egr valve changed last year that’s all good. It dose feel like it has loss of power but the turn dose feel like it kick still. When it’s warm it sound spot on, by the way it has done 117k,
  24. Hello. I’m new to the forum. Can anyone help? my 2007 pathfinder (my pride and joy) has started requiring me to randomly unlock it from the passenger side and then silence the alarm with the fob. Normally it works fine from the fob or the door buttons but then it randomly stops working. Once unlocked it goes back to working again for a while. I’ve changed batteries etc but I am out of ideas. Thank you
