	JimM joined the community
	Lee butterworth joined the community
	All radar and safety systems failing every 10 seconds 2019 QTobiasJ replied to TobiasJ's topic in Qashqai Club's Topics Just out of the blue. No prior incident or anything out of the ordinary.
	  Replacing CD/NAV unit in Murano 2009 (Z51)Trevor replied to Andrew B's topic in Nissan Murano Forum I have used a company before that specialise in aftermarket audio replacement https://www.iceboxauto.com/nissan-murano-2015-18-gps-navi-android-auto-11-carplay-oem-style-radio-ni072 Not sure if the one listed is the same style as it states it for a later model?
	  All radar and safety systems failing every 10 seconds 2019 QTrevor replied to TobiasJ's topic in Qashqai Club's Topics `when did the fault start - following an accident or body damage?
	TobiasJ joined the community
	Farah joined the community
	Neilpro joined the community
