  1. Last week
  2. Many thanks for this. Really helpful reply. Greg
  3. try Samco hoses - they are silicon and can be made to length and shape https://samcosport.com/car/
  4. Hi, I own a 2012 Micra which I love. I'm struggling to find a radiator hose for it 215033HD1B. I don't want to scrap it just for a hose - can anyine help?
  5. As long as the rolling diameter (overall diameter of the wheels / tyres) is the same all round then it shouldn't flag an ABS issue. You are able to have matched wheels on each axle and again they would need to be the same diameter as the others but do not need to be the same width
  6. I’m looking for a radiator for our scargo, damaged is ok providing the bottom tank is ok many thanks
  7. Earlier
  8. Hi all, I am the third owner of my 1994 Nissan Altima. I'm looking to get some help and advice on repairs that it needs. Can somebody point me in the right direction to which forum I would use I don't really see a Nissan Altima forum. Alternatively I could just say what's wrong with it here. I need to swap out the knock sensor and I'm not really sure how to get to it. If anybody knows the procedure I would be grateful. The knock sensor is behind the engine below the intake manifold.
  9. Hi there I have two Nissan Micra’s. One registered in 2017 has alloy wheels with tires 185/55 R16. The other car, registered in 2006 has steel wheels with tires 175/65 R15 T. My question is, can I fit all four steel wheels onto the later car or can I put two steel wheels on the same axle of the later car? Any advice would be much appreciated. Greg
  10. Hi all, I’m trying to replace the alternator on my 2017 Nissan Micra K14 Visia 1.0L (71PS – HR10DE engine), but I’ve hit a wall trying to get the belt off. I’ve located the tensioner pulley (the black one just above the alternator), but the centre is smooth — no bolt head or nut — and I can’t for the life of me find where to apply a tool to release the belt tension. I am no mechanic either .... wheels and fluids is usually my limit! I’ve checked above, behind, and around the tensioner pulley but can’t see a square hole or hex boss to rotate the tensioner arm. The engine bay is tight, and I’m not sure if I’m missing something obvious or if access is just that hidden. I’ve tried to follow online guides and videos, but most are for different engines or older models (K12/K13). Photos attached if that helps (can add more if needed). Any help — diagrams, tips, tooling advice — would be massively appreciated before I lose the will to live or call a mechanic 😅 Thanks in advance!
  11. Hi there, I have a 2022 Nissan Qashqai J12 Tekna (36 CAM, etc.), and my current display screen looks like this: [img]https://i.ibb.co/ZR3WXYr2/Screenshot-2025-06-19-at-11-48-41-Used-2022-BLUE-Nissan-Qashqai-1-3-Di-G-T-MH-158-Tekna-5dr-Xtronic.png[/img] I’m looking to upgrade it to this screen: [img]https://i.ibb.co/xZpfPGP/Screenshot-2025-06-19-at-11-48-30-Used-2022-GREY-Nissan-Qashqai-1-3-Di-G-T-MH-158-Tekna-5dr-Xtronic.png[/img] Can you confirm the following: Is this a direct plug-and-play swap? Will all existing cameras and sensors still function correctly? Is a PIN code or any additional programming required? Thanks in advance for your help! Best regards,
  12. thanks admin. I'll take some pics, and post later. Any views on the 1.2 engines?
  13. Welcome to the Club Bob
  14. Welcome to the Club
  15. Does anyone use this forum? was going to add............ I had to have the Thermostat & plastic casing replaced, costing £445. That's pretty much why I asked the question 😉
  16. Hi, New to the forum, as I just purchased the above Qashqai (Blue) Please don't tell me I've purchased a lame duck? I like it so far, but others don't, so I've read elsewhere. it's taking me a while to understand all the steering wheel gumph etc. I'd like to know what others' opinions are here please?
  17. You should be able to find a set of halogen headlamps which are completely different to Xenon type Try Partsfinder or eBay to see if there is a pair for sale
  18. Hi folks. Im new to this, but im trying desperately to sell my 1989 silver nissan sunny. She's in good condition and has been garaged for 10 yrs. Iv had it from New, so one owner. She needs a service,MOT and taxed⁷. She's nearly 40yrs old and the milage is 130,000... shes an old lady with plenty of life her still. Thanks for readying my story.
  19. Can I replace my Xenon Headlights with halogen units?
  20. Hi all Had my 2015 qashqai tekna over a year now with 49000 miles and 1 garage vist for a snapped coil spring.lol
  21. Does anyone on here have one of these & want to tell me all about it please ??
  22. Hello, I’ve just joined and thank you. I’m from Aberdeenshire in the UK. I am getting a 2019 41k miles diesel Micra soon, the dealer says they will change the cambelt and give it a 6 year service. Does anybody know what should be getting done for that service? thank you Neil
  23. I have experienced something very similar. On researching a "fix" I found that holding down the central on/off/volume button for 10 seconds will reset the system.
  24. Has anyone else lost the back up alert sound? Camera works fine but lost alert sound.
  25. Morning all! I'm looking at replacing my disc and pads on my nissan pulsar. Could I ask if anyone has a pdf workshop manual or one they would recommend for changing brake disc and pads on a MK3 (2016) Nissan Pulsar?
  26. Afternoon all! I'm looking at replacing my disc and pads on my nissan pulsar. Could I ask if anyone has a pdf workshop manual or one they would recommend for changing brake disc and pads on a MK3 (2016) Nissan Pulsar?
  27. Hello , it has been awhile since last posting a/c stoped chilling and garage found small leak and sorted. But fitter said that the main radiator fan was not coming on and could cause problems with high temp /pressure in a/c system.cannot find anything about checking fan motor. Not a lot of space to access it . Does the fan have a fuse?
