  2. My son is the proud new owner of a 2006 X-Trail T-30 as his first vehicle. Generally, it's in great condition, but it does need some bodywork to deal with rust. We are seeking recommendations on where to look online for replacement parts, ideally in Canada but open to internal suggestions. Specifically: Left Quarter Extension Left Quarter Reinforcement Thank you in advance for any advice or experiences.
  4. Last week
  5. Hi Iv just picked up a 2017 micra with the 0.9ltr engine in from Copart. It’s got a slightly rough idle, Iv just replaced the plugs and oil and filters on the car as I don’t know the history. It’s done 54k miles the evap system seem to be working ok. I don’t have a vacume pump to check properly but it’s not getting blow by out the dipstick or the filler cap. im a bit to remove the throttle body and clean it but after this I’m kinda stumped. Unfortunately my code reader is showing nothing on the system and there is no lights on the dash. Short of replacing all the coil packs I’m stuck. Any ideas?? on start up it also has a high idle as well seems to sit around 1500 and then drops off to around 800. I’d expect this on a cold morning for the cold start but it’s not been cold.
  6. Hi all, Stuart hers from Scotland and I have just purchased a 2013 Qashqai tekna 1.5 diesel with 71k on clock. I will be using this car to drive to Spain and wondering if there is anything I need to address before I start the journey. Many thanks, Stuart.
  7. Earlier
  8. Firstly thanks to admin et all for the inclusion of your forum ...... Had a Navara some years back ... dreaded chassis issue and managed a buy back from Nissan Nordics as I live in Sweden. .. Just bought a 2018 NV300 and am trying to remove the drivers arm rest to fit an aftermarket seat cover... centre cap removed and a plastic long squared centre piece revealed.... any clue on how to remove please?... Have put grips on it and tried to ease it free and even put a shifter on it to hopefully slacken it off .... but to to avail ....any one had any experience with this that they could pass on valuable info? Thank you in advance Dox
  9. hi Because I am very happy owner of Nissan Cima 2010 VIP model I imported another Nissan ..now classic 1994(late model from September) very rare with Automatic ACTSUS system. and here is a little clip with my Nissan. NEAR all works as it's looks .I need help with 2 things. Im pretty sure all 4 gas spheres( similar to Citroen with hydroactive suspension )dont have enough Nitrogen pressure and Im looking to buy 4 speheres after regeneration or refuel mine. And second problem Im trying to find Consult in my car and REALLy cant..I spoke 2 days with 2 different AI and they are giving me excluding answers. I found some of this car models DONT HAVE it.. AT ALL- I dont have any problem - nothing flash but I want to have possibility to diagnose my car if anything happend.Would be nice if some one of You have more experience with this BEAUTY and can help me. Here is How its look: here is small clip with my BEAUTY NISSAN
  10. You could try IceBox Autos who make units to specifically fit your car
  11. Our 2018 Micra K14 does not have the Carplay unit fitted which is annoying my wife who is the main driver. Does anyone please know if there is a aftermarket Carplay unit that actually works that we can have fitted to this vehicle?
  12. I would suspect it is the brake pads moving backwards and forwards - usually happens if the pads fitting kit is missing and allows the pads to move in the carrier. If it was the driveshaft joint then it would be constantly be clicking on acceleration and deceleration
  13. Did you resolve the issue? I was thinking it may be the Dual Mass Flywheel (if manual transmission) starting to break up Usually noticeable when switching the engine on/off when it will start to rattle
  14. a quick search with Google Lens reveals some results Just right click over the image above and select search with Google Lens and it brings up results of products that roughly match the clips you're looking for
  15. So, here's the saga. Offside Drum collapsed inside, my fault- long story. Anyway, new drums, studs, bearings, shoes, spring kit purchased, but could I find an ABS ring for the pixo anywhere? Nope! Eventually, Vertu Nissan offered me 2 rings for £201!!! Bought 2 used drums, cleaned/painted and fitted. ABS light turned off 👍 Moral of the story: Parts like this are becoming very difficult to get. Also, does anyone have any ABS rings? I have 2 brand new drums, with new bearings pressed in and ready to. They'll need the fings fitted, obviously. You can have them both for £50 plus whatever the p&p will be Tony
      • 1
      • Like
  16. occasionally i get a noise from the o/s/r of my car and a red warning light flashes briefly on the dash(i think it is a master warning light) .After a second the light and noise disappear and everything is ok. Performance and braking are not affected . The noise sounds a bit like ABS Working . Had rear pads replaced and a recent Mot all ok. Noise returned briefly a couple of days ago again just for a second .Usually happens on or near a corner .Any ideas???
  17. Hi, my mum has a 2005 Micra, she doesn’t want to sell it, ever. It has c40k mileage and drives like a dream! But, the tailgate switch has failed and I’m struggling to get a replacement - it’s the intelligent key version - part number 25380AX10B. Any ideas please?? There loads of the 25380AX60B but these aren’t compatible with the intelligent key. Thanks in anticipation!
  18. Hi, my mum has a 2005 Micra, she doesn’t want to sell it, ever. It has c40k mileage and drives like a dream! But, the tailgate switch has failed and I’m struggling to get a replacement - it’s the intelligent key version - part number 25380AX10B. Any ideas please?? There loads of the 25380AX60B but these aren’t compatible with the intelligent key. Thanks in anticipation!
  19. I am really sorry to hear that -sadly you don’t have dig deep to see lots of other people in the same boat. I am afraid I found Nissan completely awful to deal with- I really hope you have better luck as we have lost thousands. Citizens advice suggested approaching the car finance company if you have a finance deal because claims can be made outside the warranty of the vehicle. Trading standards are also worth contacting - the more of us who contact the DVSA with evidence I think the better - because engine failure without warning is very dangerous, particularly as this is such a popular family car. I am planning on sending details about this issue to car journalists. I hope you get a happier resolution.
  20. Exact same thing just happened to me this weekend, car just stopped with no warning! I'm going to try and claim through my finance company claiming a breach of my consumer rights but i'm not hopeful. Looking online it seems the problem is endemic!
  21. Hi, We have a 2009 Nissan Micra K12 and after a replacement Parcel shelf clip as per the attached picture. Can anyone advise on a part number or where they can be purchased?
  22. Hi, welcome to the Club Good to have you onboard!
  23. Hello All, Hope everyone is doing well and keeping happy. Wondering if anyone can shed some light, have a late 2017 Nissan QQ 1.2 DIG-T. When you rev up the vehicle as the revs start to drop back down you can hear a single thud sound (sounds like hitting a bongo drum) Thank you very much
  24. Hey all, Hope life has been treating you well. I have an odd, So I have a Nissan QQ 1.2 dig 2017. I have noticed that when move off in reverse or set of forward you get a clicking noise from front driver side wheel (see video: https://youtu.be/btICZDUeN4E?si=Z_dPz4Ju8Nc86824 but it only does it once on the initial reverse set off or forward set off which would suggest it's not something getting caught. You can make it also do it, if you are in reverse gear, holding the brake and letting out the clutch pedal all whilst stationary Things done: I have inspected all suspension components. There is.in and out play in of drive shaft. 2) Checked.dog.bone mount. 3) checked for play in wheel / wheel bearing 4) check with wheel on for anything catching. If anyone has any ideas? Thank you
  25. Hi everyone Just joined, so saying hi from sunny Brighton. I have recently purchased a Nissan Qashqai (2010) model and loving it so far jay316
  26. Thank you yes haven’t given up yet as we really looked after our car so feel it is pretty unfair 🙃
  27. its amazing how powerful the media can be in resolving such issues with manufacturers - keep trying as you may get a good outcome
  28. Thank you - the ombudsman is the direction we are heading but I am surprised the DVSA has not taken it seriously as I have read about lots of other people who had the same experience but in much more dangerous situationseg: on motorways and again with no dashboard warnings. Nissan have apparently revamped this part a few times but shocked how they have washed their hands without any help.
