  2. Last week
  3. Hi All, My name is Trevor (TDS) and I have just joined club. have just purchased a Nissan Qashqai e-power from Vertu motors in Stockton. I was previously at Toyota C-HR owner. I am looking forward to driving such a great looking car.
  4. Hi all newbie here based in Northamptonshire recently brought a 2010 NAVARA 146 k on it been meticulously looked after by previous lady owner for 8 years dog walker I was told just wanted to say hello any input on issues or what I can do would be great
  5. Hi guys n gals Has anyone attempted to retro fit roof rails to a 2022 model ?
  6. I'm having trouble finding the front turn signal (original two-phase) on the left side of the Nissan Pathfinder 2002, does anyone know where to buy one?
  7. I have a 2019 xtrail t32 2019 tekna and looking to put in a viofo dashcam with parking mod and hardwire it in does any one what fuse to plug in for permanent power when car is park and fuse when car is running
  8. I'll be driving in rain on the Interstate and all of a sudden, the cruise control shuts down and the vehicle dramatically slows down. Dash says "Frontal collision" isn't working? WTH causes this?
  9. I had the 1 litre engine in my last Juke. Its turbocharged so there is no loss of power. I now have a 1.6 Hybrid which is more cost effective especially around urban areas.
  10. Earlier
  11. Hello all, meet Jimi. 1.2 Tekna, just past 37000 miles, owned for 2 weeks. My first Juke, loving it.
  13. I've been re-bushing the suspension on my Sunny Coupe and dicovered how rusty the brake splash shields are but I cannot find replacments. Do you know of someone who might have them?
  14. I would say it is more likely to be a gummed up turbo vanes fault which can be rectified by cleaning the turbo with a specialist cleaning solution (link below) https://www.ebay.co.uk/itm/292493130747?_skw=turbo+cleaner&itmmeta=01JTSXMZ9VE9ZW9F2H1DCM6423&hash=item4419f2fbfb%3Ag%3Ab9sAAOSwYutasp0A&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1fpV%2F8bmO6dppPkpUyUyyrTVatA%2BtxVHfyIQW%2BFrQfBfOZwB9GXDgirF%2FZx1wYQ5QWHnndTFW8dxHQnQwE2DJPM593%2FytgJBS5MLBDp8GWH%2FZutClKfIZWQSfoKddANZ7zaeBnZAo6VVmNaP6AcQjlZrAqIw0vsohppQpa1TRGcxd4sUcRwemDzU%2FgJBiFCwMC0j2OXXqnhoSWOhG9lxLcC0VLM4FFWpJ0NKLa%2FFsrMcFmbgwWZs209wAa7IvVnY8g%3D|tkp%3ABlBMUIL1073WZQ&keyword=turbo+cleaner&sacat=0&relatedSearch=true Once you have cleaned it and the vanes are free to move then a good italian tune-up should blast out any residue and carbon and should then run smoothly
  15. I would say that is an air conditioning system sensor - possibly system pressure sensor?
  16. Hi, I’ve replaced the horn in my 2005 Urbis and managed to accidentally break the wire next to it that goes into the radiator. Can anyone kindly confirm what it is and what it does so I can get a new part?
  17. okay, best bet really.....let us know how you get on with it
  18. Hi .... and welcome to the Club Great to have you onboard and feel free to post and answer any questions you feel able to answer. The Juke is a great car, my wife has one and just keeps going with minimal repairs (if any) but always maintained to keep it reliable.
  19. Hi guys hope your all well, I'm very thrilled to have found this group of nissan like minded people (how did i not know about this)🤣, I myself own a 1.5 2014 juke and absolutely love it, do you guys ever put on meets at all?
  20. Thank for this, but not confident enough to try myself, ill try and find a garage
  21. I would have a go yourself - switch ignition off and leave for half hour. (be careful as this is pyrotechnics and therefore explosive charge) Disconnect the electrical connectors under each seat, twist the wire one turn (so it has a slight bias on the connection when refitting) and reconnect. That may well solve the issue but because it is intermittent then it may not bring the light on straight away.
  22. Thanks, I would have thought this is something the nissan dealers would look at
  23. Hi all, Looking for some assistance. Recently encountered an issue with my 17 plate juke tekna where the power drops off in gears 4, 5 & 6 when trying to reach above 45mph - eventually reaches 60-70mph but have to feather the acceleration pedal and when foot is slammed to the ground and going uphill the revs start to drop and the car slows down as if there’s no power first instance the amber engine management light came on but didn’t have the OBD2 reader to scan and check. Car has since had a major service and fault cleared but has returned with no engine management light OBD2 reader showing fault P0380(glow plug/heater circuit A) and P1453(manufacturer control) assuming manufacturer control is limp mode? But surely any fault that drops the car into limp mode would throw up other lights on the dash attached pics of OBD2 codes any help would be appreciated, cheers
  24. Here's a problem to bake your noodle. 1995 k11 Micra, not been driven for a month, 4 new problems have appeared, all lights. 1) left headlight not working. 2) left indicator telltale light not working, either in telltale or hazard mode, external lights all working and relay clicking. 3) handbrake warning light not working. 4) reversing light not working. I'm going to do all the usual checks, starting with the external bulbs, but these systems can't have anything in common, can they?
  25. What colour? there is a set of black seats on eBay at the min. item number is 316640688205
  26. I would advise someone look at the connections under both front seats for the SRS seatbelt pretensioners as they usually flag up a fault if the connection is poor
  27. Hi, My mum has a 2006 1.4 Micra SVE that has a fault with the seat belt in that the dash light comes on intermittently. We’ve been advised by the dealer that the fault is with the buckle(driver side) but the parts are no longer available so i would have to try and track one down which i did on ebay but after 3 trys they were all faulty, i found another through a breakers but Nissan mechanical said its the wrong one, even though it fitted and has not gone off yet. Can anyone offer any advise on how to fix this or maybe where i can find the correct part, thanks.
  28. It would seem, and I would wholeheartedly agree. Although, technically, you could leave all previous weights on a wheel for forever, and just keep balancing it with additional weights as necessary!??? 😂 Not the case here though. All the weights are fresh new. They put both push on weights and stick on weights. Push on weights went to the inside of each wheel. Stick on weights are to the outside behind the spokes on the aluminum mag wheels. And.. as stated.. opposite each other in three of the four, and about 2 hours on the clock location off opposite on the fourth. It’s very weird. I have personally balanced a lot of motorcycle wheels in my life.. and it’s always one weight.
