Noisy Sunroof
Thank you I will have a look and try that.
NickJ joined the community
Not entirely sure but I have only ever encountered a few methods of retaining the gear knob. Grub screw (usually small and hidden underneath the knob, screwed thread (twist off), detent clip (needs pulling up with force) - beyond that I'm not sure. I would start with trying to locate the grub screw, if not then gently try twisting anticlockwise, then if no joy then try knocking it upwards (I tend to hold onto the gear knob and with your other hand wallop your gripping hand to force it up. Beware to keep you face out of the way :-)
Trevor started following Electrical issues with the 2020 Kicks and 2005 Bluebird Sylphy G10L shifter removal
Sluggish Qashqai
Sluggish Qashqai
Yes its quite normal for the hoses to expand when pressurised from the turbo boost however, if they feel very soft and squidgy when you squeeze them they are probably in need of replacement as the rubber would be perished with age
Noisy Sunroof
Greetings and salutations!
Simonius joined the community
Sluggish Qashqai
Riles joined the community
Decent price for it
Cheers for this
Noisy Sunroof
Jeannie joined the community
Rstuner joined the community
Katman joined the community
Problem turning on radio
problem with my CV Joint
Decent price for it
Decent price for it
my radio is knackered
Sluggish Qashqai
Sluggish Qashqai
Sluggish Qashqai
Sluggish Qashqai
