Vinny joined the community
Arno P joined the community
Pete Nice joined the community
bing joined the community
Malcolm S joined the community
HOLLIE COWLEY joined the community
Wargra joined the community
Nissan Owners Club started following Hi all
Welcome to the Club Bob
Welcome to the Club
Does anyone use this forum? was going to add............ I had to have the Thermostat & plastic casing replaced, costing £445. That's pretty much why I asked the question 😉
