  2. ALFIE BEAUMONT joined the community
  4. George Roston joined the community
  5. nissanSerbia92 joined the community
  6. Hi guys i have a provlem with my CV joint
  7. Last week
  8. Thx mate. I'll keep that in mind.
  9. If it is screaming high pitch noise then it is more than likely got a small leak somewhere but in general you will hear a nice constant low whistling tone while the turbo spools up
  10. Thanks for that Trevor. Needless to say, appart from the classic high pitch turbo sound, I hav'nt really paid much attention to anything else. I'll listen tomorrow and get back to you.
  11. Sounds like turbo boost isn't there - are there any strange sounds like whistling or a deeper sound (sounds like a burp) as this can signify that either the turbo or intercooler is leaking and creates a whistling sound and if its deeper then one of the rubber turbo hoses is split. I would demonstrate both sounds but luckily I can't record sound on here 😁
  12. I would be very tempted to take it back to the dealership and ask them to explain it to you - not only is it from the Nissan dealership so they should be well informed of any procedures and also the liability if there is any issues with the system. Please let us know how you get on with it
  13. Hi Just bought a new Qashqai 1.3, and swapping out from a Volvo Xc40 In the Volvo I had capability to press two buttons on the steering wheel. This made the car recognise speed signs and keep the speed as per speed restrictions. Would not allow me to exceed the limit. Nice a simple. No concerns on unintentional speeding.. I was informed by Nissan sales my new car has this capability. So far struggling to figure how to do this assuming it can be done...Took a look on Google and found something's linked to TSR ICC and ProPilot. But unsure. So anyone in this forum, any idea what I am talking about and is it feasible.. appreciate any guidance.
  14. howard Crisp joined the community
  15. Hi to everyone. Happy to announce that I've just joined and would any ideas as to why my 2014 Nissan Qashqai 1.6dci is so sluggish on standing acceleration. Once it picks-up it seems to be ok but generally tired. I suspect a turbo issue. I would appreciate any info related to this
  16. yavcan started following Sluggish Qashqai
  17. yavcan joined the community
  18. Cheers thanks
  19. caseyannabell joined the community
  20. Hi, I would say Halfords but probably not on your model, I guess any decent independent mechanic should be able to change it. Not only is it the one lamp at the moment but they usually follow in pairs. I can recommend a mobile mechanic, Sam Mee who is top-drawer and would be able to do that job (assuming it doesn't need to be from underneath on a vehicle lift to access the bulb). Let me know if you want his number and I can PM it to you. Being based in Bournemouth myself I know many garages and some/most I would not advise going to but there are also a lot of very good garages and mechanics out there who are respectful of customers and their cars. (I know because I taught many of them over the years). Give me some garage names (best PM them to me) and can advise on their reputation as best I can. Cheers, Trevor
  21. I would recommend taking the car to an car audio specialist I believe there are still some left in most towns. They may be able to guide you to a reset or firmware update - alternatively they may offer to sell you a new multimedia replacement which would be so much better than the original one
  22. how low was the warning down to? maybe less than a certain amount (e.g. zero or very low timeframe) and it won't reset unless through a scanner.
  23. Not sure to be honest but found this AI summary which could shine some light on your issue TSR Audible Warning Details: Speed Limit Change: A single chime sounds when the system detects a new speed limit sign. Overspeed Warning: If the vehicle exceeds the detected speed limit, the display flashes and a chime sounds four times. Customization: Within the [Driver Assistance] > [Traffic Sign Assist] menu, drivers can set the system to: [Warning]: Both visual speed limit display and audible overspeed chimes are active. [Info only]: Only the visual display is active; audible alerts for speed changes are disabled. Temporary Suspension: The chime can be temporarily muted by slowing down or using the steering wheel scroll dial.
  24. Abs
  25. Hi the oil change duration button doesn’t work anymore on my 2010 note. Is it possible to reset another way?
  26. welcome back john!
  27. Hi @Johnj good to see you back 🙂
  28. Trevor started following Nice to be back
  29. Good evening, I wonder if anyone can help/advise. My NS headlight bulb has gone and needs replacing, Nissan Dealers quote dover £350 just to replace it. does anyone know of a reputable Nissan non-dealership that I can go to, am based in Bournemouth. Thanks
  30. JJBMTH joined the community
  31. OK, know the sd card is out of date it keeps telling me, awaiting new one thing is I used my CD player yesterday fine but to day it as started playing up it plays CD but but volume will not work or any of the other bottons but if I eject the CD radio will play and dose the same with volume and I can not switch it off tryed doing a reset with on off botton t worked the once and that was it can't Evan get to the setting menu ether, 2011 model
  32. Hi nice to be back
  33. Abs
  34. Hi guys I recently bought a 2023 Qashqai Acenta Premium, and have a query re the alert system. Essentially, when Traffic Sign Recognition (TSR) identifies a speed limit, and I exceed this limit, all that happens is my speed flashes on the dashboard by way of a warning - but I get no audible "warning chime" - like I've expereienced in other Qashqais. I've had a look at the options in the Driver Assistance menu - and the only options I see for TSR are "On" or "Off" - no "info only" or "warning", like I've seen is the case for other models. If the only option is on/off, I'd have though an audible chime would be the default - but I can't see where else this could be muted in the system. Has anyone else experienced this? Thanks!
  35. MrBishMan joined the community
  36. Randigyrl joined the community
  37. Deutsch: Hallo, wie ich sehe habt ihr das selbe Problem wie ich, an meinem Quashkai j11 mit 1.33 Liter Benziner. Ich habe auch ein gerichtliches Gutachten, auf deutsch. Leider hat der Gutachter nicht genau sagen können, mit was der Schaden angefangen hat. Das Thermostat und das Gehäuse, die Kopfdichtung und der Flüssigkeitsströmungsbegrenzer sind defekt . Die Wasserpumpe war in Ordnung. Während der Fahrt, kam bei mir auch kein Warnsymbol am Display. Erst später, als ich schon mit dem Auto am Straßenrand stand. Der Motor hat sich fest gefressen und das Kühlwasser ist sofort entwichen. Erfahren habe ich auch, dass der Quashkai J11 keinen Sensor besitzt, der erkennen kann, wie viel Kühlmittelwasser noch während der Fart vorhanden ist. Dies hat der Gutachter schriftlich bewiesen. Und meine Abgassensoren, die normaler weiße auch eine Meldung zeigen sollten, haben beide eine Funktionsstörung gehabt, laut Lesegerät vom Gutachter. Also höchstwahrscheinlich sind die Kabeln wie bei einem anderen Nutzer weggeschmolzen. Habt ihr bereits welche Resultate erziehlen können? Habt ihr auch irgend etwas schriftliches, wie ein Gutachten ? Damit ich es dem Gericht vorweisen kann? Ich habe nämlich noch Garantie und Gewährleistung auf dieses Auto. English:Hello, I see you have the same problem as me with my Quashkai j11 with a 1.33-liter gasoline engine. I also have a court report in German. Unfortunately, the expert was unable to say exactly what caused the damage. The thermostat and housing, the head gasket, and the fluid flow restrictor are defective. The water pump was fine. While driving, no warning symbol appeared on the display. Only later, when I was already standing on the side of the road with the car. The engine seized up and the coolant immediately leaked out. I also learned that the Quashkai J11 does not have a sensor that can detect how much coolant is still available while driving. The expert proved this in writing. And my exhaust sensors, which should normally also display a message, both had a malfunction, according to the expert's reading device. So most likely, the cables melted away, as was the case with another user. Have you already achieved any results? Do you also have anything in writing, such as an expert opinion? So that I can present it to the court? I still have a warranty and guarantee on this car. Translated with DeepL.com (free version)
  38. Thank you so much for responding with the solution - I'm sure many members will benefit from your time in diagnosing and cost (albeit a cheap component) rather than replacing everything in a process of elimination.
